Re: [Digital BW] Problems with QTR
2005-04-02 by Diane Fields
Steve, I thought it might be because you didn't convert to the gray-matte or gray-paper profiles, but just tried a 'color' tiff to see if it would open it and it did--so my theory is hogwash LOL.
I'm assuming you are PC since you are using the GUI.  I haven't ahd any problems with any of my tiffs.  Are they 16 bit?  I thought I read where the new version would allow 16 bit but convert to 8--but perhaps you have one of the older versions?!?
Perhaps someone else has a thought about this also.
Diane
  Sent: Saturday, April 02, 2005 3:08 PM
  Subject: [Digital BW] Problems with QTR
  I downloaded and installed Roy Harrington's QTR only to discover that
  my Tiff files won't open in the QTRgui software. I keep getting a
  message "Unsupported Format" in the little window where the image
  should be viewed? Does anybody know why this is happening?
Re: Problems with QTR
2005-04-02 by Steve
Thanks, Diane, ooops..found the solution to my problem. Had the Tiff
Image Compression setting at "jpeg" rather than "none". Now it seems
to work just fine, which leads me to my next question about the QTR.
Why is there NO image preview on the GUI to show you the changes you
make when moving to sliders to adjust Gamma adjustments or curves?
How does one know which setting to use?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Diane Fields"
> Diane
>   ----- Original Message -----
>   From: Steve
that
a
