Wireless printing
Wireless printing
2005-04-03 by Tom OConnell
Anyone doing wireless printing?
I'm looking to build a wireless print server (or blue tooth or whatever
will work) for an Epson 4000 and 2200 (and maybe an 1850) and would
like to not reinvent the wheel.
If anyone is doing this successfully, I would love to hear what
hardware you like.
thanks,
Tom O'Connell
Wireless printing
2005-04-03 by Stephen Kobrin
I use a D-link wireless router which  provides for both wireless
connectivity to the Net & access to a printer from any wireless enabled
computer in range.  I use it with a laser printer, but see no reason it
would not work with any printer. It does require a parallel
connection,but other routers may have USB ports. It was very simple to
setup.
Steve
Re: [Digital BW] Wireless printing
2005-04-04 by Anthony S. Tubbs
Well the easiest way to do it if your runnig a wireless network allready
is to get a linksys printserver it comes in two version wireless  or
wired both can have USB or Parell Ports.  Even if you have a complete
wire network you can use the wireless one as it hooks into your network
wired also.  SO then all wired computer or wireless ones can print to
the hook up printers.  Right now I have two printservers and run a HP
laser, Epson RX500 all in one, Cannon i900, Cannon i6000D in the near
will get  rid of the Cannons and getting the 1800 and 2200 or the just
the 4000 not sure yet.  Thats why I join this group to learn about Black
and White printing.  The cheaper route for me would be the C86 and
1800.    Anthony
>setup.
>Steve
>------------------------ Yahoo! Groups Sponsor --
2005-04-04 by Tom OConnell
Hate to be obtuse...but...
I'm using a dlink router now. Are you saying I can just get a lynksys
printserver with a usb port and plug all my printers into a hub and
plug the hub into the wireless print server and that's it??? I thought
only some printers could be networked? does the usb print server make
them all work???
thanks
tom
yes any printer can be used on a printserver in the printer properties
you just have to make sure you have the port set up. I have not tried
the hub but I see no problem with hooking up a usb hub and connecting
that to a printserver usb port and configure your printer to see the
server and them tell your printer what port. any problems you can email
off line. this is somewhat easy.  anthony
>them all work???
>thanks
2005-04-04 by Kip Cole
I've tried a Belkin wireless print server to connect my Epson 2100
with minimal success.  Apart from driver issues causing lack of
reliability and very slow performance, the fact that the server did
not support bidirectional communications was a pain - StatusMonitor3
wouldn't work.  You can mark the virtual port "unidirectional" in
its properties, but that doesn't seem to help reliability in this
case.
I think that many wireless print servers do not support
bidirectional communications, so that may need checking.
Second, check that it support USB 2.0 (not just 1.1).
--Kip
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Anthony S.
properties
tried
connecting
email
lynksys
and
thought
make
> >them all work???
> >thanks
2005-04-04 by Dave
I've got both OS X Macs and PCs (XP), and I need to share an Epson 1270 between all my
computers. I'd love to have the printer on the network with a wireless (or wired) print
server, but I haven't been able to tell if it would really work. The Mac and XP PC are in
different rooms, so a USB switch is not a possible solution. It seems that laser printers are
often in a different category, because some of the sharing schemes require the use of
PostScript.
Has anybody succeeded in setting up something similar? What hardware did you use?
Anthony, what operating systems are you running?
Thanks!
2005-04-04 by B. Ellis
I don't have a Mac and a PC but I do have two PCs with different operating
systems (XP and ME). One of the PCs is connected to a 1280 in one room and
the other PC is connected to a 2200 in a different room. I can print to the
2200 from either computer using NetGear wireless equipment (about $200 at
Comp USA).
Sent: Monday, April 04, 2005 10:24 AM
Subject: Re: [Digital BW] Wireless printing
between all my
wired) print
XP PC are in
laser printers are
the use of
PostScript.
use?
Thanks!
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
David: here's what I did to share a couple printers between three
computers.  I run XP-win2000 and a version of OS/2warp called
eComStation if you don t know windows does not like to play nice with
it.  I had the HP1300 which has a USB and Parelle Port on it, hook the
USB to a Linksys usb print server and let all three computers set up
their own driver for the print server and installed the hp drivers.
Then I hook up another print server and hook up a Epsom C80/84 to it did
same thing the print servers were wired servers hook into a 10/100 hub
hook directly into the ports on the Router, which the separate computers
were also hook up. I have not been able to make OS2 and the wins play
with each other but I am able to print to all printers with all OS's and
go out on the Internet.  I then hook up a Epsom RX500 USB into XP and
let win2000 printer thru XP when needed.  I then hook up two Cannon's
into the win2000 and did the same thing. Problem with eComStation is
some of the newer printers don t have drivers.   At work we have a NT
server and I bought in a parelle port print server  I had left over and
hook up it and NT and my win2000 box and the new xp's can all see the
print server and print to the printer without going thru NT server.
Sometimes the NT boxs print to the printer real slow,takes a while for
print job to start once starter prints normal.  I have not had that
problem at home though.
I have also hook up a printer this way too. eComStation and XP  the OS2
box hook up to the parelle port and the XP hook up to the USB port,never
had a problem printing from either box.  That may be a way for you, does
not the 1280 have USB and parelle ports.                Anthony
>PostScript.
>Thanks!
