> -- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
> <paul.roark@v...> wrote:
> > Ben,
> > What I've occasionally had is a black line that is caused
> by "junk" (dried
> > pigs, I assume) on the head deflecting one or more jets off to the
> side. I
> > have always been able to cure this by cleaning the head with
> Windex that is
> > on a folded paper towel or, best, a 1/2 inch strip of bias tape
> (available
> > in the sewing sections of many stores, including Wal-Mart). (I'm
> looking at
> > a package of Wrights Single Fold 1/2" bias tape.) Before I had
> the bias
> > tape, I'd cut and fold a paper towel to about 1/2 inch.
> > I soak the tape with Windex, turn off the printer, release the
> head by
> > rotating the white gear at the left toward me, raise the head (for
> thick
> > paper), lay the soaked tape in the channel over which the head
> travels, move
> > the head over the tape, lower the head, grab ends of the tape, and
> pull it
> > back and forth across the head. Then, of course, put the head
> back in its
> > place the move the gear back to lock the head.
> > This should knock and pigment build-up off the surface of the head.
> > I also rinse the parking pads periodically with windex or "UC
> base" (4 parts
> > H2O to 3 parts glycerin. MIS may sell this as "UC base." I mixed
> it for
> > diluting UC inks. It has no binder in it, but the water and
> glycerin -- an
> > excellent dispersant and humicant -- will clean the sponge
> nicely. I also
> > use the UC base for printer storage. No binder or pigs should
> mean no
> > clogging.)
> > Once I've cleaned the heads and pads, one cleaning cycle usually
> has
> > resulted in the errant line disappearing.
> > Good luck.
> > Paul
> > www.PaulRoark.com
> > > -----Original Message-----
> > > From: ben_zlotkin [mailto:ben@b...]
> > > Sent: Saturday, April 02, 2005 11:50 AM
> > > To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > > Subject: [Digital BW] Epson 1280 with MIS UT printing problem
> > > Im fairly new to this, so if this is a common problem that has
> been
> > > covered - please just
> > > point me in the right direction.
> > > Im printing with the MIS UTFSN cartrides (Matte Black) on an
> Epson 1280.
> > > The paper is
> > > Epson EM.
> > > The problem Im having is with images where one area has heavy
> deep black
> > > shadows.
> > > 'Below' these areas I am getting dark lines after the dark
> section(s). By
> > > below, I mean the
> > > section the print head covers after it has covered the dark
> section. It is
> > > as if the black ink
> > > flow (or another dark black) does not shut down as fas as it
> should. By
> > > the time the print
> > > head is back at the other side of the print and starting its
> next run, the
> > > problem is gone
> > > until the dark section is covered again.
> > > This is hard to explain - if someone knows what Im talking
> about, please
> > > let me know.
> > > Otherwise, I'll post an image on Monday.
> > > Thank youall for your time, Ben Z
> > > Please visit the Group Homepage to check the Files, and other
> resources as
> > > they are often being updated.
> > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > > If you wish to receive no emails or just a daily digest, or you
> wish to
> > > unsubscribe, please edit your Membership preferences by visiting
> this same
> > > page.
> > > Please follow these basic guidelines:
> > > - As threads develop, trim off excess portions of earlier
> messages to keep
> > > them short.
> > > - Good manners are required at all time. No personal attacks or
> flames.
> > > Hostile, aggressive or argumentative users may be removed from
> the
> > > membership without notice.
> > > - Keep your posts and threads related to the group topic of
> digital B&W
> > > printing. Users who persistently make off-topic posts may be
> removed from
> > > the membership.
> > > - By posting on this forum you agree to abide by the group rules
> and
> > > guidelines, and to abide by the actions and decisions of the
> group Owner
> > > and Moderators. See "Group Topic, Rules and Guidelines" in the
> Files
> > > section:
> > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
> THE PRINT
> > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
> AND
> > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO
> > > YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL
> OR
> > > EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR
> LOSS OF
> > > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF
> THE
> > > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP
> HAVE BEEN
> > > ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i)
> THE USE
> > > OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP;
> (ii)
> > > UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR
> DATA; (iii)
> > > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
> PRINT
> > > YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL
> BW, THE
> > > PRINT YAHOO GROUP.
> > > Yahoo! Groups Links
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
