BO/1280/clogging
BO/1280/clogging
2005-04-04 by Drime
This is a follow up on the recent 1280 clogging thread.
After reading the posts re the above I have decided to use MIS Eboni in
the new EZ cart right from the start in my new 1280. I seek advise and
input regarding the other cart. Maybe use UT2 inks in the new T009
cart?
Many thanks
Drime
Re: BO/1280/clogging
2005-04-04 by Bob Michaels
I just use the MIS $5 el cheapo dye color cart when printing BO using
Eboni. I have no problems and it's the cheapest ink to use up for
nozzle checks and the automatic cleaning cycles.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Drime
> cart?
> Many thanks
> Drime
2005-04-07 by jim0266
Drime,
Since I BO print on my 1280 with Eboni and I recently went through an
ordeal getting my printer back go perfect nozzles, I am going to load
MIS UC Base in my T009 spongeless cart and "print" with that. You can
find it at http://www.inksupply.com/ut7500.cfm. It's ESC-BASE-4-UC
"Flushing Fluid." When the printer does a cleaning cycle it will dump
the cleaning fluid on the pad.
Jim
> cart?
> Many thanks
> Drime
