Refillable cartridges for Epson 1280
2005-04-16 by adolphamster
I've been reading a great deal about the problems people have had with
the MIS refillable cartridges. Now that the dust has settle somewhat
I'd like to hear opinions as to whether this is a prudent way to go vs
the conventional cartridges. I'm using an Epson 1280 and have been
using MIS UT2 and UTK prefilled cartdridges.
Thank you.
Re: Refillable cartridges for Epson 1280
2005-04-16 by Steven Karafyllakis
I've been using the 1280 carts since they were released, with
absolutely no problems. I should mention that when I got them, there
were no filler-hole plugs, so I've been using silicone, which may be a
more secure way of closing the fill port. IOW I suspect many of the
problems relate to air leakage through the fill port changing the flow-
rate of the cart. Pre-filled carts are obviously easier, but they are
much more expensive, and in that color cart wastefull since you never
deplete all chambers of ink. I reccommend you give the refilling a try,
you can always switch back.
Steve Karafyllakis
 -- In DigitalBlackandWhiteThePrint@yahoogroups.com, "adolphamster"
> Thank you.
2005-04-19 by adolphamster
I attempted to follow up on your suggestion but the MSI web page
indicates that the refillable cartridges are not now available for the
1280!!
But thanks anyway. I ordered some conventional filled cartridges and
will look for the refillable ones next time I order.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
there
be a
flow-
are
never
try,
> Steve Karafyllakis
with
somewhat
go vs
> > Thank you.
2005-04-19 by Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "adolphamster"
> 1280!!
That's a shame, sounds like I got lucky if they had enough complaints
to pull the carts. I hope they'll get a fix from the factory and bring
them back soon!
Steve Karafyllakis
