Re: MIS UT2 CIS from 1280 in a Stylus Photo
2005-04-22 by Jerry in Houston
Thanks Don for your help ... I bought mine on ebay, refurb, for $69 + shipping and received it yesterday. I have installed the OEM inks to check out the machine and am blown away by both the BO and color prints on EEM I have gotten. I am thinking of getting another to use with what color pics I want. I have developed a problem that I think is a Photoshop problem, not a printer problem in that it no longer wants to print in color using PS7 while the same pic loaded in Irfanview will print in great color. Have uninstalled and reinstalled the latest Epson driver but no joy. I have not yet taken on installing the MIS UT2 CIS inks but it looks like a pretty simple install. I am actually thinking about buying a couple of the new clear refillable carts, they are cheap enough, and just using the inks I have from the CIS and avoid all the tubing. BTW, what is the CMCMY config? and you say you use Pauls regular UT2 curves? Sounds interesting, Jerry in Houston <<Jerry, I have just installed MIS UT Full Spectrum inks with Eboni black in the new CMCMY configuration in my Stylus Photo 900. Using Paul's curves, the prints are quite stunning on any matte papers that I have thrown at it. As these inks and curves are specifically for the 1280, I can only assume that your inks will work in a similar fashion. Since the 900 uses the same inks as the 1280, you get the larger capacity color cartridge with the small format printer. Also, they are going for a steal online, but I purchased mine from Arditios as a close out for 109 (new). Don >>
