I reinstalled all of the applications this past weekend following
the need to format my hard drive. Prior to that, OPM worked fine
including psd as a choice from the import file list. The problems
arose following the reinstall.
I used the *.* choice when psd files (as a separate choice) no
longer appeared. This did display the psd files but to no avail.
They would not preview nor open even after selected. Converting a
psd file to tif in PSCS was an effort at a work around but again to
no avail. The file appeared but when selected, no preview and the
address access violation error message prevented any printing.
I have emailed Joe and have yet to hear from him. Hopefully he will
provide some solution.
N. Schwartz
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina"
<lbdina@c...> wrote:
> When you whent to import the file, did you select All File Types
from
> the file type drop down box? PSD files display and open fine for
me.
> If that is not the issue, I'd send Joe an email.
> Lou
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "nsapc"
> <nsapc@y...> wrote:
> > I cannot import, preview nor print any psd images under Win XP
with
> > a 2200 Epson. I can print a test image and jpeg's. The psd file
> > option does NOT appear in the file type drop down menu of the
import
> > dialogue box.
> > I converted a psd image to tif in PSCS. I could import but not
> > preview or print this file. The error message "Access Violation
at
> > address 00422FBB in module OPM.exe. Read of address 00000000".
> > I suspect Quicktime 6.5.2 may be involved in the issue. When
> > installing, I checked the box to view psd images.
> > N. Schwartz
