Re: [Digital BW] A few QTR Newbie Questions
2005-05-04 by dschiemann
Question 3:  I have switched between photo and matte black cartridges several times, holding the reserve one upright with a piece of scotch tape over the ink nozzle, and have had no problems.
Donald
2005-05-04 by Djon
You're probably risking more with the tape goothan without tape. I've
read (fwiw) that carts are self-sealing...
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dschiemann"
> Donald
2005-05-05 by Scott McLoughlin
Thansk. Switching matte/photo on the 2200 should be one headache to
not have :-)
Scott
> Donald
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd
> AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> *Yahoo! Groups Links*
>     * To visit your group on the web, go to:
>     * To unsubscribe from this group, send an email to:
>       DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
>       <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Using reflection densitomer to linearize output
2005-05-05 by Peter De Smidt
I recently started printing using a C86, Mis EZ inks and Paul's
settings. So far, my prints on PremierArt Hot Press using Pauls settings
come out darker than my calibrated monitor. (I've also got Kirkland
paper on the way.)  Both the high print values (lighter values) and the
low print values (darker values) print too dark. This is especially
noticiable in the lower print values which lose a tremendous amount of
detail compared to the screen image.  I've tried the Zuber Photographic
method of setting a black and white adjustment curve, but this didn't
have much effect. Could I use my MacBeth reflection densitometer to make
a Photoshop CS curve that would get me better output? Perhaps by
printing a step wedge, taking readings, and making a custom curve? I've
looked for a description of a good method on the web, but I've come up
short. Any suggestions?
On another front, I'm having some problems with what traditional
photographers call 'pepper fogging', something that Sterling Lith paper
did all too often when using Tim Rudman's Lith printing method.
Basically, once one got the dilute lith developer to the near exhaustion
stage, usually the stage that would give the most interesting results,
all of a sudden small black specks would appear on the print.  Well, I
get these specks on my inkjet prints, and they're really annoying. With
silver paper, I'd use tincture of iodine on a sharpened toothpick to
bleach the spots, re-fix, wash, dry, and spot to get rid of the specks.
Are these black pin pricks of ink common to ink in otherwise light
smooth toned areas unavoidable with inkjet printing? Can anything be
done to prints that have them? For example, can they be knifed out?
Peter
2005-05-05 by Djon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Scott McLoughlin
> not have :-)
It isn't a headache...easy as pie, zero problems, perhaps better than
more complex systems.
Re: Using reflection densitomer to linearize output
2005-05-05 by Djon
Peter,  pepper grain:
Are you scanning? I had pepper almost always (depending on film stock)
with Nikon's scanning application, vanished it totally when using that
application neg>neg>pos but then produced MUCH better results
(startlingly good...better than my own good silver prints) with ease
using VueScan Pro (don't recall why I got the "Pro" version, maybe I
was feeling inferior that day).
I've not seen pepper with Nikon since switching to VueScan or ever
with Epson flatbed/Silverfast/Epson OEM, even blown up to 12X18.
2005-05-05 by Phil Rose
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Peter De Smidt
settings
Stating that you have a "calibrated monitor" doesn't tell enough about
your situation, as it give no information about the luminance value
your monitor is adjusted to. If you have your monitor adjusted to a
high luminance value --e.g., near (or antwhere above) 100 cd/m2, then
you will be having exactly the problem you describe. The easiest
solution would be to adjust the monitor luminance to a more reasonable
level, which (IMHO) is somewhere around 85 cd/m2. Your prints will
match better, and your eyes will appreciate the "rest".
Of course if your prints had _not_ been relatively too dark when you
previously were printing with other printers/inks/paper, then I
suppose your problem lies elsewhere (something other than level of
monitor luminance).
Phil
Re: [Digital BW] Re: Using reflection densitomer to linearize output
2005-05-06 by Peter De Smidt
>monitor luminance).
>Phil
My monitor is calibrated with the PhotoCal spyder.  I'm not sure what
the luminance level is, but I'll re-calibrate tonight when it's
completely dark outside.  I should be able to tell when I do this.
My color prints on the C86 and Epson Premium Glossy paper turn out just
fine.
-Peter
