Epson K3 Inkset Permanence Rating
2005-05-15 by Andre
2005-05-15 by Andre
http://www.wilhelm-research.com/epson/9800.html
2005-05-15 by Paul Roark
> > > http://www.wilhelm-research.com/epson/9800.html The Note on the right of the introduction of the B&W section says: "The Display Permanence Ratings given here are based on long-term testing with the previous generation of UltraChrome inks." So, we have no specific new B&W display life information. The WIR note continues: "WIR testing to date with UltraChrome K3 inks indicates that significant increases in Display Permanence Ratings for black-and-white prints can be expected because the three-level, high-stable carbon pigment based black inks in the UltraChrome K3 inkset largely replace the ... color inks ..." The introduction also notes, "The last of the Iris Graphics continuous flow, dye-based inkjet printers originally used by Nash Editions was retired in December 2004." It all makes me wonder if Epson may be re-thinking its "Giclee" marketing and predominantly "proprietary dyes and pigments" Material Safety Data Sheet description of their black inks. I hope someone who buys a 2400 will supply me with a test strip to test against the MIS UT inks as soon as possible. That should be interesting. Meanwhile I see Kodak has yet another new top management person. Good luck. It's going to be hard to watch the Titanic attempt to steer away from the iceberg with its way too small rudder. Paul www.PaulRoark.com
2005-05-15 by Steve Kale
Footnote 1 suggests that prototype K3s were used....I think they are all over the place and Wilhem likely is simply under pressure to support the Epson promotion. I have tried to get an ETA on the new printers from Calumet here in London to no avail. I do think I am likely to be an early jumper on one of these - albeit I can't make my mind up as to whether the extra size of the 4800 really is that much bigger than the 2400....
> From: Paul Roark <paul.roark@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Sun, 15 May 2005 08:55:37 -0700 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: RE: [Digital BW] Epson K3 Inkset Permanence Rating > >> >> >> http://www.wilhelm-research.com/epson/9800.html > > > The Note on the right of the introduction of the B&W section says: "The > Display Permanence Ratings given here are based on long-term testing with > the previous generation of UltraChrome inks." > > So, we have no specific new B&W display life information. > > The WIR note continues: "WIR testing to date with UltraChrome K3 inks > indicates that significant increases in Display Permanence Ratings for > black-and-white prints can be expected because the three-level, high-stable > carbon pigment based black inks in the UltraChrome K3 inkset largely replace > the ... color inks ..." > > The introduction also notes, "The last of the Iris Graphics continuous flow, > dye-based inkjet printers originally used by Nash Editions was retired in > December 2004." > > It all makes me wonder if Epson may be re-thinking its "Giclee" marketing > and predominantly "proprietary dyes and pigments" Material Safety Data Sheet > description of their black inks. > > I hope someone who buys a 2400 will supply me with a test strip to test > against the MIS UT inks as soon as possible. That should be interesting. > > Meanwhile I see Kodak has yet another new top management person. Good luck. > It's going to be hard to watch the Titanic attempt to steer away from the > iceberg with its way too small rudder. > > Paul > www.PaulRoark.com
Steve, One could also read the WIR notes as indicating the "new" UC K3 inks are basically just UC inks, with the addition of the LLK and a lot of hype. Personally, I think the 2400 would be high on my list, but I'm going to wait for a dual K large format machine. The black ink changing may be fine for a service bureau, but not for the type of printing I do. Paul www.PaulRoark.com
> -----Original Message----- > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@...m] On Behalf Of Steve > Kale > Sent: Sunday, May 15, 2005 8:18 AM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: Re: [Digital BW] Epson K3 Inkset Permanence Rating > > Footnote 1 suggests that prototype K3s were used....I think they are all > over the place and Wilhem likely is simply under pressure to support the > Epson promotion. I have tried to get an ETA on the new printers from > Calumet here in London to no avail. I do think I am likely to be an early > jumper on one of these - albeit I can't make my mind up as to whether the > extra size of the 4800 really is that much bigger than the 2400.... > > > > From: Paul Roark <paul.roark@verizon.net> > > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > Date: Sun, 15 May 2005 08:55:37 -0700 > > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > Subject: RE: [Digital BW] Epson K3 Inkset Permanence Rating > > > >> > >> > >> http://www.wilhelm-research.com/epson/9800.html > > > > > > The Note on the right of the introduction of the B&W section says: "The > > Display Permanence Ratings given here are based on long-term testing > with > > the previous generation of UltraChrome inks." > > > > So, we have no specific new B&W display life information. > > > > The WIR note continues: "WIR testing to date with UltraChrome K3 inks > > indicates that significant increases in Display Permanence Ratings for > > black-and-white prints can be expected because the three-level, high- > stable > > carbon pigment based black inks in the UltraChrome K3 inkset largely > replace > > the ... color inks ..." > > > > The introduction also notes, "The last of the Iris Graphics continuous > flow, > > dye-based inkjet printers originally used by Nash Editions was retired > in > > December 2004." > > > > It all makes me wonder if Epson may be re-thinking its "Giclee" > marketing > > and predominantly "proprietary dyes and pigments" Material Safety Data > Sheet > > description of their black inks. > > > > I hope someone who buys a 2400 will supply me with a test strip to test > > against the MIS UT inks as soon as possible. That should be > interesting. > > > > Meanwhile I see Kodak has yet another new top management person. Good > luck. > > It's going to be hard to watch the Titanic attempt to steer away from > the > > iceberg with its way too small rudder. > > > > Paul > > www.PaulRoark.com > > > > > > Please visit the Group Homepage to check the Files, and other resources as > they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to > unsubscribe, please edit your Membership preferences by visiting this same > page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages to keep > them short. > - Good manners are required at all time. No personal attacks or flames. > Hostile, aggressive or argumentative users may be removed from the > membership without notice. > - Keep your posts and threads related to the group topic of digital B&W > printing. Users who persistently make off-topic posts may be removed from > the membership. > - By posting on this forum you agree to abide by the group rules and > guidelines, and to abide by the actions and decisions of the group Owner > and Moderators. See Group Topic, Rules and Guidelines in the Files > section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND > MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO > YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN > ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE > OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > PRINT YAHOO GROUP. > > Yahoo! Groups Links > > > > >
Hi Paul Well it certainly is easy to be cautious re the new inks. My first printer was the 2100 and I was simply amazed at what it could achieve but rather quickly I become disappointed with the matte paper blacks and the photo paper finish. Disappointed in a very relative sense! It would seem to me that if a high quality photo paper finish can be achieved with a dMax of over 2.3 then the matte papers are in trouble and the ink switching issue is lessened considerably. (I suspect I have wasted much more ink due to poor MIS carts although at least the ink is a lot cheaper to begin with.) If they really have killed the bronzing/gloss differential issue it is going to be great. Time will tell as to whether the early fluff has substance. On another note I think all potential purchasers of these printers in the UK need to unite and complain to Epson re their pricing. The 4800 has an MSRP of £1,756 (incl VAT). That's almost the USD price but with a £ sign instead of a $ sign. Don't they know £1.00=$1.85... Cheers Steve
> From: Paul Roark <paul.roark@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Sun, 15 May 2005 09:56:57 -0700 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: RE: [Digital BW] Epson K3 Inkset Permanence Rating > > Steve, > > One could also read the WIR notes as indicating the "new" UC K3 inks are > basically just UC inks, with the addition of the LLK and a lot of hype. > > Personally, I think the 2400 would be high on my list, but I'm going to wait > for a dual K large format machine. The black ink changing may be fine for a > service bureau, but not for the type of printing I do. > > Paul > www.PaulRoark.com >
2005-05-15 by Djon
Kodak turned the digital corner a long time ago, its future as a digital player is assured. Kodak became the biggest digital player as early as 1980...I saw their digital B&W high speed recording camera (for mechanical engineering research) at a PMA show in Las Vegas back then. It was $10K...cheaper and faster than film cameras and of course much cheaper to operate. This camera eventually killed off estar-based high speed recording film, such as the beloved 2475. Kodak dominates the 4/3 chip manufacturing format in partnership with Fuji...IMO that format will win in the end, rather than APS or full frame 2X3, because it allows physically smaller/cheaper cameras/lenses (like Olympus, which uses Kodak/Fuji chip). Digital Ice is a Kodak baby. In the most recent Calumet catalog a letter from the president vaguely semi-assures us that they will sort of continue to somewhat try to provide B&W traditional materials as long as feasible, sort of. My best local E6 lab has posted a similarly vague statement on EK letterhead. EK shareholders will be happy to see the last nail driven in the coffin. Djon > > Meanwhile I see Kodak has yet another new top management person. Good luck. > It's going to be hard to watch the Titanic attempt to steer away from the
2005-05-15 by Ernst Dinkla
Paul Roark wrote: >One could also read the WIR notes as indicating the "new" UC K3 inks are >basically just UC inks, with the addition of the LLK and a lot of hype. > > > Given Wilhelm's notes and preliminary numbers there can't be much difference to the first UCs. But the gloss is better according to Joseph Holmes. The speed can be reduced to get gloss differential better he writes but the 4800 is already faster than the 4000 and certainly much faster than the 9600 so that's hardly the way to achieve that result. I guess the pigments are the same but there's a media change (glop added or whatever without sacrificing Dmax). He also describes some hue shifts for CM in the new inkset. He seems to be more familiar with the 10000CF than the first UC models but he must know what he is writing about. Ernst
