Cleaning fluid and clogs
2005-05-21 by Paul Roark
I had a persistent clog in my 7600 that would not go away.  So, I loaded
cleaning fluid into all the positions, did an "initial fill," and let it sit
for more than 2 weeks.
It appears to have worked.  I re-loaded UT7 and the nozzles are all perfect
again - not a single cleaning cycle was needed.
Hopefully this will last.  If not, it's time for new dampers.
At any rate, the point is that leaving the cleaning fluid loaded for a long
time seems to be able to dissolve through persistent clogs - as MIS had
suggested.
Re: Cleaning fluid and clogs
2005-05-21 by dfaprinting
loaded
let it sit
perfect
for a long
had
> suggested.
> Paul
If this was the normal flushing/cleaning fluid, there is a more
aggressive cleaner that you can get. Request Image Specialists
product number WJ800. Cost is about $5.20 per 16 ounces, so I expect
MIS would mark it up to around $7-10 per 16 ounces. This may be a
special order product.
