IJC/OPM Update - Recreate profiles
2005-06-03 by keithd2010
Does anybody know: With the new higher ink limits for certain printers (like my 1280) do the profiles need to be recreated?
2005-06-03 by Louis Dina
If the ink limits for your printer model changed, you will need to readjust your profiles if you want to use the new version. Lou --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "keithd2010" <kdouglas@q...> wrote: > Does anybody know: With the new higher ink limits for certain printers > (like my 1280) do the profiles need to be recreated?
2005-06-03 by Joe Berndt
On 6/3/05 1:08 PM, "keithd2010" <kdouglas@...> wrote: > Does anybody know: With the new higher ink limits for certain printers > (like my 1280) do the profiles need to be recreated? > Yes, The older profiles will need to be adjusted. If you start with cutting the existing limits in half, you will find that an older profile will then be very close. What I do is once I¹ve set the new lower limit, I then can slowly increase just the black ink up. This lets me play around with the increasing D-Max. The trick is not to go too high, too much ink can re-duce D-Max. Joe Berndt [Non-text portions of this message have been removed]
2005-06-04 by Bill Morse
Does this apply to all the inks, or just the black? Thanks, Bill Morse Digital Eye Editions 450 Harrison Ave. Studio 227 Boston, MA 02118 (617) 429-3298 http://digitaleyeeditions.com on 6/3/05 6:02 PM, Joe Berndt wrote: > On 6/3/05 1:08 PM, "keithd2010" <kdouglas@...> wrote: > >> > Does anybody know: With the new higher ink limits for certain printers >> > (like my 1280) do the profiles need to be recreated? >> > > > Yes, > > The older profiles will need to be adjusted. If you start with cutting the > existing limits in half, you will find that an older profile will then be > very close. What I do is once I¹ve set the new lower limit, I then can > slowly increase just the black ink up. This lets me play around with the > increasing D-Max. The trick is not to go too high, too much ink can > re-duce D-Max. > > Joe Berndt > > > [Non-text portions of this message have been removed] > > > > Please visit the Group Homepage to check the Files, and other resources as > they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to > unsubscribe, please edit your Membership preferences by visiting this same > page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages to keep > them short. > - Good manners are required at all time. No personal attacks or flames. > Hostile, aggressive or argumentative users may be removed from the membership > without notice. > - Keep your posts and threads related to the group topic of digital B&W > printing. Users who persistently make off-topic posts may be removed from the > membership. > - By posting on this forum you agree to abide by the group rules and > guidelines, and to abide by the actions and decisions of the group Owner and > Moderators. See Group Topic, Rules and Guidelines in the Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND > MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, > USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF > DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, > THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR > TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE > DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE > DIGITAL BW, THE PRINT YAHOO GROUP. > > > > > Yahoo! Groups Links > * To visit your group on the web, go to: > * http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/ > * > * To unsubscribe from this group, send an email to: > * DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com > <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsub > scribe> > * > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service > <http://docs.yahoo.com/info/terms/> . > [Non-text portions of this message have been removed]
2005-06-04 by Louis Dina
The ink limits were increased on all ink positions for specific printers. It's not that difficult to switch over. Let's say you had a profile for a 2200 on EEM that you wanted to use as a basis for your 7600. Let's also assume the 2200 had the black ink limit set at 24 for that profile. The other ink limits would be set at different points. If you printed an ink limit chart with IJC/OPM for your 7600, and it showed that you get the deepest black at step 14, you could ratio your ink limits in the new profile as follows: Set black ink limit to 14 (per your ink limit test chart). Then ratio back your ink limits using 14/24 (or 0.58) as the multiplier. So, if the LK ink position was previously set at 15, you would adjust it to 8 (14 X 0.58 = 8.17). Do the same for the rest of the active inks. This will get you very close to where you want to be. Then if you wanted you could make final tweaks to perfect the profile to your tastes. If you had previous profiles for your printer, you would do the exact same thing. This assumes you are keeping the inkset and papers the same, of course. Lou --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Bill Morse <whm.lists@v...> wrote: > Does this apply to all the inks, or just the black? > > Thanks, > > Bill Morse > Digital Eye Editions > 450 Harrison Ave. Studio 227 > Boston, MA 02118 > (617) 429-3298 > > http://digitaleyeeditions.com > > > on 6/3/05 6:02 PM, Joe Berndt wrote: > > > On 6/3/05 1:08 PM, "keithd2010" <kdouglas@q...> wrote: > > > >> > Does anybody know: With the new higher ink limits for certain printers > >> > (like my 1280) do the profiles need to be recreated? > >> > > > > > Yes, > > > > The older profiles will need to be adjusted. If you start with cutting the > > existing limits in half, you will find that an older profile will then be > > very close. What I do is once I¹ve set the new lower limit, I then can > > slowly increase just the black ink up. This lets me play around with the > > increasing D-Max. The trick is not to go too high, too much ink can > > re-duce D-Max. > > > > Joe Berndt > > > > > > [Non-text portions of this message have been removed] > > > > > > > > Please visit the Group Homepage to check the Files, and other resources as > > they are often being updated. > > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > > If you wish to receive no emails or just a daily digest, or you wish to > > unsubscribe, please edit your Membership preferences by visiting this same > > page. > > > > Please follow these basic guidelines: > > - As threads develop, trim off excess portions of earlier messages to keep > > them short. > > - Good manners are required at all time. No personal attacks or flames. > > Hostile, aggressive or argumentative users may be removed from the membership > > without notice. > > - Keep your posts and threads related to the group topic of digital B&W > > printing. Users who persistently make off-topic posts may be removed from the > > membership. > > - By posting on this forum you agree to abide by the group rules and > > guidelines, and to abide by the actions and decisions of the group Owner and > > Moderators. See "Group Topic, Rules and Guidelines" in the Files section: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU > > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY > > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, > > USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF > > DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH > > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, > > THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR > > TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE > > DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE > > DIGITAL BW, THE PRINT YAHOO GROUP. > > > > > > > > > > Yahoo! Groups Links > > * To visit your group on the web, go to: > > * http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/ > > * > > * To unsubscribe from this group, send an email to: > > * DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com > > <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com? subject=Unsub > > scribe> > > * > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> > <http://docs.yahoo.com/info/terms/> . > > > > > > > [Non-text portions of this message have been removed]
2005-06-05 by Paul Roark
I've placed scans of the old and new ink densities on my web page, at the bottom of the index at http://home1.gte.net/res09aij/index.htm. This might also help translate the old ink limits into the new. This was printed on a 7600 with UT7 on EEM, but the relative outputs might be close to others. Pull the image into Photoshop and use the eyedropper to measure the density of the patch that represents the old ink limit you set. Then use the eyedropper to find the new ink limit that prints at the same density. Hope this is helpful. Paul www.PaulRoark.com
> -----Original Message----- > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Louis > Dina > Sent: Saturday, June 04, 2005 3:41 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: Re: [Digital BW] IJC/OPM Update - Recreate profiles > > The ink limits were increased on all ink positions for specific > printers. > > It's not that difficult to switch over. Let's say you had a profile > for a 2200 on EEM that you wanted to use as a basis for your 7600. > Let's also assume the 2200 had the black ink limit set at 24 for that > profile. The other ink limits would be set at different points. > > If you printed an ink limit chart with IJC/OPM for your 7600, and it > showed that you get the deepest black at step 14, you could ratio > your ink limits in the new profile as follows: > > Set black ink limit to 14 (per your ink limit test chart). Then > ratio back your ink limits using 14/24 (or 0.58) as the multiplier. > So, if the LK ink position was previously set at 15, you would adjust > it to 8 (14 X 0.58 = 8.17). Do the same for the rest of the active > inks. > > This will get you very close to where you want to be. Then if you > wanted you could make final tweaks to perfect the profile to your > tastes. > > If you had previous profiles for your printer, you would do the exact > same thing. This assumes you are keeping the inkset and papers the > same, of course. > > Lou > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Bill Morse > <whm.lists@v...> wrote: > > Does this apply to all the inks, or just the black? > > > > Thanks, > > > > Bill Morse > > Digital Eye Editions > > 450 Harrison Ave. Studio 227 > > Boston, MA 02118 > > (617) 429-3298 > > > > http://digitaleyeeditions.com > > > > > > on 6/3/05 6:02 PM, Joe Berndt wrote: > > > > > On 6/3/05 1:08 PM, "keithd2010" <kdouglas@q...> wrote: > > > > > >> > Does anybody know: With the new higher ink limits for certain > printers > > >> > (like my 1280) do the profiles need to be recreated? > > >> > > > > > > > Yes, > > > > > > The older profiles will need to be adjusted. If you start with > cutting the > > > existing limits in half, you will find that an older profile will > then be > > > very close. What I do is once I¹ve set the new lower limit, I > then can > > > slowly increase just the black ink up. This lets me play around > with the > > > increasing D-Max. The trick is not to go too high, too much ink > can > > > re-duce D-Max. > > > > > > Joe Berndt > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > Please visit the Group Homepage to check the Files, and other > resources as > > > they are often being updated. > > > > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > > > > If you wish to receive no emails or just a daily digest, or you > wish to > > > unsubscribe, please edit your Membership preferences by visiting > this same > > > page. > > > > > > Please follow these basic guidelines: > > > - As threads develop, trim off excess portions of earlier > messages to keep > > > them short. > > > - Good manners are required at all time. No personal attacks or > flames. > > > Hostile, aggressive or argumentative users may be removed from > the membership > > > without notice. > > > - Keep your posts and threads related to the group topic of > digital B&W > > > printing. Users who persistently make off-topic posts may be > removed from the > > > membership. > > > - By posting on this forum you agree to abide by the group rules > and > > > guidelines, and to abide by the actions and decisions of the > group Owner and > > > Moderators. See "Group Topic, Rules and Guidelines" in the Files > section: > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > > > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, > THE PRINT > > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" > AND > > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE > LIABLE TO YOU > > > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > EXEMPLARY > > > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > PROFITS, GOODWILL, > > > USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" > AND "MODERATORS" OF > > > DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE > POSSIBILITY OF SUCH > > > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE > DIGITAL BW, > > > THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION > OF YOUR > > > TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD > PARTY ON THE > > > DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER > RELATING TO THE > > > DIGITAL BW, THE PRINT YAHOO GROUP. > > > > > > > > > > > > > > > Yahoo! Groups Links > > > * To visit your group on the web, go to: > > > * http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/ > > > * > > > * To unsubscribe from this group, send an email to: > > > * DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com > > > <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com? > subject=Unsub > > > scribe> > > > * > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service > > > <http://docs.yahoo.com/info/terms/> . > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > Please visit the Group Homepage to check the Files, and other resources as > they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to > unsubscribe, please edit your Membership preferences by visiting this same > page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages to keep > them short. > - Good manners are required at all time. No personal attacks or flames. > Hostile, aggressive or argumentative users may be removed from the > membership without notice. > - Keep your posts and threads related to the group topic of digital B&W > printing. Users who persistently make off-topic posts may be removed from > the membership. > - By posting on this forum you agree to abide by the group rules and > guidelines, and to abide by the actions and decisions of the group Owner > and Moderators. See Group Topic, Rules and Guidelines in the Files > section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND > MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO > YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN > ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE > OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > PRINT YAHOO GROUP. > > Yahoo! Groups Links > > > > >
