Advice needed... 4000 vs. 4800???
2005-06-07 by John Broski
Hello All, I'm currently using a 2000P (with UT2 ink) for B&W and a 1270 (with MIS Glossy Pigments) for color. Both printers are fitted up with CFS systems. The black ink in the 1270 is not part of the CFS, but uses MIS spongeless carts, to allow for easy changeover between PK and MK. The UT2 on the 2000P does both surfaces, of course, with no changeover. (Thanks, Paul!) Both systems work great most of the time, though I do a fair amount of tweaking and cleaning to keep the CFSs going strong. I have never used a RIP. But just when things are going good... I've got the itch to move to a bigger printer. I do equal amounts of color and B&W, and I do both glossy and matte (pretty much equally). I would like to experiment more with BO printing, but the 1270 bands and the 2000P is too coarse for my taste. I'm starting to sell some prints, and so I've got a bit of money to reinvest into printing gear. The 4800 will be around $2000, I guess. The 4000 is around $1600 from online sources, with a $300 rebate that's good til June 30. So, call it $1300. (Actually $1250, delivered, from ebuyer.com, after rebate.) I'd like to simplify my life and have just one printer, and use UC inks. Now... do I have the pros and cons straight? Both printers are built like tanks, and both accept the big 220ml cartridges for economy. It sounds like the 4800 will do good B&W and color, on gloss and matte paper, right out of the box. But it requires a MK-to-PK changeover that costs about $38 each time. And some sources indicate that its BO performance is not good. The 4000 does good matte color, but some say it takes spraying to get good gloss color (because of differential reflection). With QTR, I understand it will do good B&W using the UC inkset, though I guess spraying is still needed with glossy paper? But it carries both blacks onboard. And it does good BO printing. So it sounds like the only real downside of the 4000 is the need to spray on glossy paper. How real is that problem? Are some semi-matte/semigloss papers acceptable with UC inks without spraying? Any other factors I ought to consider? Advice welcome! Thanks, John Broski
