QTR on 9600 not printing long panorama - cutting off after 44"
2005-06-16 by john dean
Anyone,
Sorry to bother you guys but am in a bit of a spot.
I have this contract to print a 12 foot x 24" panorama for a public installation
on my 9600 UC and am not able to figure out what QTR is doing with my file.
When I start the job everything is going fine but 44" into the length of the print
the printer stops and the print is trimmed. Though I am using a large roll I have
tried this twice with both the QTR roll setting as well as the sheet paper
setting. Since I was doing these on 44" rag paper it has already cost me quite
a bit in wasted paper and I not sure what to do at this point.
On a related note I was not able to send this file through Photoshop CS to the
printer ( it would not allow me to access the print menu ) when the file was set
to 240 dpi. Strangely enough I was only able to make that work when I
reduced the dpi of the print file to 150 dpi but the output look good. I don't
understand this either, because it certainly wasn't a memory issue as it was
only about a 200 meg file and I have printed several QTR files in print sizes
much larger, say 44"x50" @ 240 dpi with no problems, but nothing this long.
This job is set up on a dual 450 G4 with 1.5 gigs of ram using the latest
version of Panther. I  could use my G5 if I had to but I don't think this has
anything to do with the Mac, it is something related to QTR.
Finally, before I contracted to do this job I did a test on the same system on
cheap paper of the exact length I am working with but only a strip, not the
entire file, and it was output at only 72 dpi to save the long duration that it
would take to do this file. That went through fine all the way to the end.
Any suggestions or persons to contact regarding this would be appreciated.
I am on a time crunch. There is always something, huh.
John
Re: QTR on 9600 not printing long panorama - cutting off after 44"
2005-06-16 by dfaprinting
Regarding not printing from PhotoShop:
Could this be an issue with the total number of pixels? I seem to
recall that there was a limit on some versions of PS that would not
allow you to print correctly. 30,000 seems to come to mind, but I might
be wrong.
Also a cheaper paper suggestion: Hahnemuhle ArtProof. Still not
extremely cheap, but if you are working with the other papers in that
family, a good color match and it seems to hold just as much ink as the
other coated papers.
As far as the rest goes... sorry, can't help.
The entire file size of this print is 105 megs ( small in larger scheme of things).
The way  I tried it last night was 24"x 180" @ 160 dpi  ( pixel width was 3840 -
pixel height was 28800 pixels}.
Should I try reducing this further? You think it  might be a limitation with
Photoshop? The problem with doing anymore tests is that it wasts  a lot of ink
and it takes forever, but I might have to keep doing tests and changing
settings. I'm just not sure what to attempt. I've written Roy but I actually don't
think he any experience with large format printers and panoramas.
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dfaprinting" <
> be wrong.
Actually the 9600 has a much longer length limit than 44" when using even
the Epson driver, I do long prints color and qtr on the banner setting all the
time. But not this length.
What we are exploring here is the way the rip QTR is handling the file
throught Photoshop .  I have done many Qtr prints in the 60" length but when it
comes to this more extreme length something is happening and I don't know
what my limit is. Pixel count could have something to do with it.
Roy wrote me a couple of weeks ago that people from this list told him the
limit was 100 feet, which is far, far, beyond the 12-15' limit that I want to work
with.  I wish I knew who that was so I could ask him. This could be an issue for
a lot of people who do monochrome panoramas and want to sell them for an
installation.
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Graham" <
gebilwil@n...> wrote:
> The Epson driver/OS combination has a 44 inch limit---actually I think the
limit varies a
> bit with printer and OS, and it is a well discussed problem.  There is a paper
discussing
> this on the Epson site someplace, and a search here or on wide format will
probably find
> something.
> Anyway, a traditional solution is to tile the image in a software that
implements this.
> Illustrator comes to  mind.  There is a file uploaded on the Epson 4000
group that
> discusses how to do this.
> Also, does the current 9600 firmware/software have a banner option?  That
supposedly
> works on the 4000 with "pseudo tiling" in Photoshop.
> Scott
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john dean"
things).
3840 -
ink
don't
> > John
> > > be wrong.
I could point you to a different RIP (Windows only), but you would need
to learn how it works, as well as make CMYK profiles with the black
generation set to give you the type of print that you want. It's all
going to come down to the amount of time you have left. I can do the
profiles (and turn them around really quickly), and am fairly familiar
with this RIP in trial mode (14 days no watermarks or other
limitations). Running in the standard print mode it would all be down
to the profile.
The RIP I mention is one of my finalists in the RIP wars, really just
one other to check at this point.
If the Windows only isn't an issue, I can email you the info to get the
demo, and could email the profile targets  (if needed) to you when I
get home from work. The developer claims 100+ feet limit, though I
haven't tried anything larger than 12x18 inches. It prints from its
internal layout program, so no PhotoShop limits on pixel count.
think the limit varies a
is a paper discussing
will probably find
> something.
According to Chris at inkjetart (who is also using Macs) the limit is
92 inches with the Epson driver.
http://www.inkjetart.com/forum/viewtopic.php?p=1362#1362
I thought I had read somewhere that the limit with Windows XP was
either 96 inches or somewhere above 100 inches (can't really remember).
Thanks Greg,
I am going to stay away from Windows unless I invest in Studio Print and anoa
pc  , which for 95% of my work is not necessary since I don't create my own
profiles now.
I haven't give up on QTR yet since I was able to make it print 12' with a low
resolution strip last week.
Right now I am attempting to print the thing out of the Epson  banner driver at
160" long . It is printing but it has decided to shrink the width of my panorama
from 8" to 6" on the fly. Very strange day I'm having today.
John
> to the profile.
> Thanks Greg,
and anoa
my own
> profiles now.
Just a note about StudioPrint, for some things outside the norm,
StudioPrint may not be the best choice. Yes it has a dedicated B/W
mode, and it will allow mixing channels and setting the amount of
mixing, there are a couple things that I'm finding it won't let me do.
Things that I may want to be able to do. If it had an advanced mode
where everything was manual with no wizard to help you, I think it
would be great. But as far as I know, it doesn't have this type of
operation. I need to glance through the PDF one more time, and then go
on to the next trial that I have.
2005-06-16 by Scott Graham
Thank you for the update on length.  I obviously haven't tried it, or even really had time to try
QTR yet except for a couple of tests.  My show is up now though, so I am breathing again.
Scott
www.sgraham.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john dean" <deanwork2003@y...>
