nik sharpener pro
2005-06-20 by Stephen Kobrin
I upgraded to Nik Sharpener Pro 2.0 and there do seem to be some marked improvements. However, one of the reasons I upgraded was to get 16 bit capability. At this point, 2.0 only works with 16 bit RGB files; if you have a 16 bit grayscale file the option is still grayed out in the filter menu. Tech support said that they are working on the problem. Additionally, it is not clear to me that the new "smart sharpen" in CS2 works as well with grayscale files as it does with RGB. I have been very pleased with the results when I sharpen a RGB file, but disappointed when I try smart sharpen on grayscale. Am I imagining things or has anyone else had the same experience.\? Steve
