Improving UltraChrome density
2005-06-22 by Richard Smallfield
Hello,
I use QTR on a 2100 with UltraChromes. I also use an HP7660.
I have often used the HP for portraits because of the better density, but generally prefer the 2100 because of the neutral BW I can achieve.
I remain unhappy, however, with the UC/QTR black density and wondered if there is a way to improve this. Do I just have to accept this as a characteristic of this generation of UltraChromes?
thanks,
Richard
Portraiture and Location Photography
http://smallfield.vze.com
http://photos.smallfield.vze.com
   "The artist is nothing without the gift, but the gift
   is nothing without work."
   --Emile Zola (1840-1902)
Re: Improving UltraChrome density
2005-06-23 by Antonis
Richard,
paper is a big factor in dmax. You may get more accurate feedback here
if you mentioned what densities you achieve at 100% and on what papers.
Also, dmax varies depending on how the profile is made.
And you may compare different drivers to see which works best for your papers -
such as the Epson driver, IJC/OPM, Imageprint etc.
Antonis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Smallfield
<r.smallfield@p...> wrote:
> Hello,
UltraChromes?
> thanks,
> Richard
RE: [Digital BW] Improving UltraChrome density
2005-06-26 by Paul Roark
Richard,
Are you using matte or glossy paper?  The best glossy papers with Photo K
should be closer to the dye dmax.  Spraying the prints will get rid of the
bronzing.
If you're using matte paper, EAM or PhotoRag will probably have the best
dmax.
In addition to getting the ink limit fine tuned with your rip, what I did on
my 2200 to get the best dmax with UC MK was to put some UC Cyan into the
100% black patch.  (I did this when I had the older version of IJC, which
could not pump as much MK as the newer one or QTR, so I'm not 100% sure what
the results would be with QTR.  But I don't think I was being limited by the
rip at on the 2200.)  At any rate, to find the best mix, I believe I backed
the ink limit off one notch from where it was optimized with MK and ran a
45% curve of the cyan with the K a horizontal line, full on (but with the
limit down one notch.  The test strip then showed what amount of Cyan to put
into the mix.   Some playing around with the ratios will be needed.  The
bottom line, however, was that UC MK with a little C seemed to give a better
dmax than MK by itself, and I suspect it might be the same with your setup.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Richard
> Smallfield
> Sent: Wednesday, June 22, 2005 2:01 PM
> To: Digital BW Print
> Subject: [Digital BW] Improving UltraChrome density
> Hello,
> thanks,
> Richard
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See Group Topic, Rules and Guidelines in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
> MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
