replacing cartridges on 1280
2005-06-22 by opiebreath
You know, I think this has probably been covered somewhere in the
group
but I've searched using a variety of terms and haven't found the
thread
yet...
So, just getting in to the printing end of the process. I have a 1280
and just bought a set of MIS inks. All I've ever done with the
printer
priior to this is simply run epson or generic cartridges until they
are
empty and then replace them.
I'd like to put the MIS inks in, make some prints and then put the
standard cartridges BACK in again. So, when taking a non-empty
cartridge out of the printer do I tape over the vent and ink holes,
removing the tape when I reinsert or something else?
I'd like to be able to switch to MIS inks, doa few prints and then
swith back for "regular family use".
Milt
RE: [Digital BW] replacing cartridges on 1280
2005-06-26 by Paul Roark
Milt,
I didn't see an answer to this, so I'll take a shot.
The new clear carts from MIS have poppet valves the should work fine when
taken in and out.  I rinse the outlets with a syringe of water when taken
out just to make sure ink does not dry and then get into the printer inlet.
I then tape the outlets shut.  I don't like the rivets MIS sells to plug the
outlets.
If you are switching between dye and MIS inks that have the Eboni black ink,
I'd also rinse the parking pads every time I installed the Eboni to be sure
the dye does not react with Eboni and cause clogging problems.  To do this,
turn the printer off, open the lid and look at the left inside of the
printer.  The big gear, if rotated toward you, releases the peg that holds
the head to the right.  Then you can move the head to the left and, perhaps
with the help of a flashlight, clearly see the black sponge parking pad that
needs to be rinsed off.  I use a syringe with Windex in it to do this.  A
couple of wipes with a paper towel between rinses wouldn't hurt either.
When this has been done, move the head and gear back the way they were.
I hope this works OK for your uses.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
> opiebreath
> Sent: Tuesday, June 21, 2005 8:24 PM
> Subject: [Digital BW] replacing cartridges on 1280
> group
> thread
> yet...
> printer
> are
> Thanks,
> Milt
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
