Epson 2200 with MIS inks.
2005-06-23 by mastedward
I am a b&w photographer currently printing with either a C86 with MIS black/grey inks, or a 2200 using QTR (with Epson color inks). I am not dissastified with either, but (perhaps I'm getting greedy?!) would I gain anyhing by going to the MIS black/grey inks for the 2200? And if I did that, would I still use QTR? Thanks, Edward
2005-06-23 by SteveZ
If you are refering to MIS UT7 inks for the 2200 then, yes, definately. It's worth it. I recently started using them and it's made all the difference in the world. That ebony black is something else. You won't need to use QTR, just follow Paul Roark's workflow for the Epson driver and install his curves. You won't regret it. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mastedward" <nedmast2@a...> wrote: > I am a b&w photographer currently printing with either a C86 with MIS
> black/grey inks, or a 2200 using QTR (with Epson color inks). I am > not > dissastified with either, but (perhaps I'm getting greedy?!) would I > gain anyhing by going to the MIS black/grey inks for the 2200? And > if > I did that, would I still use QTR? Thanks, Edward
2005-06-24 by mastedward
Yes, Steve - I'm referring to the MIS UT7 inks. I am currently using them in the C86, including the eboni black. So the crux of my quetion is, does using the 7 inks in the 2200 result in a noticeably better print than the 4 inks in the C86? Thanks for your response, Edward--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "SteveZ" <blizzie12@y...> wrote: > If you are refering to MIS UT7 inks for the 2200 then, yes, > definately. It's worth it. I recently started using them and it's made > all the difference in the world. That ebony black is something else. > You won't need to use QTR, just follow Paul Roark's workflow for the > Epson driver and install his curves. You won't regret it. > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mastedward" > <nedmast2@a...> wrote: > > I am a b&w photographer currently printing with either a C86 with > MIS > > black/grey inks, or a 2200 using QTR (with Epson color inks). I am > > not > > dissastified with either, but (perhaps I'm getting greedy?!) would I > > gain anyhing by going to the MIS black/grey inks for the 2200? And > > if > > I did that, would I still use QTR? Thanks, Edward
2005-06-24 by Bernie Ess
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mastedward" <nedmast2@a...> wrote: > Yes, Steve - I'm referring to the MIS UT7 inks. I am currently using > them in the C86, including the eboni black. So the crux of my > quetion is, does using the 7 inks in the 2200 result in a noticeably > better print than the 4 inks in the C86? If I may step in, the basic quality will probably not be that different, the UT7 just gives more options like cool and warm toning. I use the 2100/ UT7 combo since a year or so, before I had the 1160 with full spectrum inks, and the 2100 is faster and also a bit better, specially on semigloss paper. However there is some bronzing on semigloss and gloss, I personally consider to get maybe a dedicated printer just to apply GLOP after the print. regards, Bernie
