Varnishing prints and Epson UC vs MIS inks
2005-06-24 by yohnnyboy
In a previous post I stated that spraying prints made on Epson
Premium Luster with MIS ultratone inks made a huge night and day
difference in the appearance of the deep blacks. I used Golden
Archival Varnish spray with gloss finish. I measured the dmax with
these results. The first number is the density of the unsprayed
print. The second value is the sprayed print.
0% 0.1 0.1
10% 0.23 0.27
20% 0.35 0.39
30% 0.48 0.51
40% 0.63 0.65
50% 0.79 0.81
60% 0.97 1.00
70% 1.18 1.23
80% 1.47 1.55
90% 1.76 1.92
95% 1.86 2.08
100% 2.02 2.28
There is a clear enhancement of dmax using the varnish. Visually, the
separation in the shadows is enhanced with the spary and there is no
loss of highlight separation. However, this particular spary
increases the gloss differential. I don't find that objectionable but
I am sure others will disagree.
Visually, the effect of the varnish on the appearance of the print is
MUCH MORE than the damx numbers would indicate. It took me a while to
figure out what was going on. After comparing prints made from many
different printers (on Ep. Prem Luster) I discovered that the MIS
INKS have a very low gloss. The Epson UC inks and in particular the
Epson pk-black ink is much more glossy. The pk-black of the epson K3
ink is significantly more glossy than the Ultrachrome pk-black.
On Ep Prem Luster the gloss of the black ink appears to make a huge
difference on the appearance of the tones. The high gloss UC ink
gives the appearance of a rich deep black in the print. The MIS black
leads to a dull appearance in the print that does not produce
a "convincing black" (These are my opinions. Whether it does or does
not is obviously a matter of taste.) This is why spraying the MIS
print makes such a huge difference in appearance to me. With a spray
the dmax of the MIS ink increases but the dull black ink surface now
takes on a glossy appearance which dramatically increases the
richness of the print.
When I spray coat a print made with Epson UC inks or K3 inks the
effect is much less noticable. Interestingly, spraying the Epson inks
also leads to an increase in dmax. However, since the Epson inks are
intrinsically glossy themselves, the print is rich in appearance
before spraying and the effect of the spray is only of minor
importance.
Re: [Digital BW] Varnishing prints and Epson UC vs MIS inks
2005-06-25 by Ernst Dinkla
>0% 0.1 0.1
>10% 0.23 0.27
>20% 0.35 0.39
>30% 0.48 0.51
>40% 0.63 0.65
>50% 0.79 0.81
>60% 0.97 1.00
>70% 1.18 1.23
>80% 1.47 1.55
>90% 1.76 1.92
>95% 1.86 2.08
>100% 2.02 2.28
>importance.
We have had the discussion on the difference between matte and gloss
Dmax, the perceptual side versus the measured data. Within the context
of gloss printing only it may be in fact much more important and a high
gloss, high Dmax (visually and/or measurable) PK may have less black
pigment in it than a less glossy PK. Trying to get as much pigment in
while still keeping gloss may be counter productive in Dmax and gloss in
the end. Best is of course an ink medium + pigment particle that has
high gloss quality together.
While testing the Fuji_Hunt paper with MIS PK and comparing them with
prints made with a 4000 I considered that there is a lot going on with
gloss and Dmax that should be taking serious. Printing the QTR target
with MIS PK and Eboni on that gloss paper I had a sample where the Eboni
was visually more black than the PK next to it while the Spectrometer
measured a higher Dmax for the PK than on the Eboni. Quite low for PK
though: 1.75 without varnish at 43 ink limit, couldn't get higher with
higher ink limits on the 9000. There must be a point where gloss and
pigmentation grade are ideal for a given paper, something you can't
control with inklimit only on PK but can control with a mix of PK and
the next grey + their ink limits (Paul mentioned better result with two
greys than with PK and that fits this theory as well though Paul's
results were not only effectuated by this phenomenon IIRIC). I'm
actually checking whether different inklimits per grey ink on the MIS UT
can keep the gloss differential better and fitting the densities based
on that instead of trying to keep the longest range of increasing
densities per grey ink. May not work though.
With that experience in mind I may try the 4800 PK ink in the 9000 UT
range, I suspected that the quoted Damx numbers are the result of a
better gloss/pigmentation mix (encapsulation of the pigment particles a
big contribution in this). I'm also wondering whether all the other
double/triple 4800 inks CcMmKkk have different gloss grades between dark
and light and by that can control the gloss difference better. An 60% c
squirts a lot more ink medium on the paper than a 20% C.
Which ink carts of the 4000 and 4800 are identical ? The MK is as far as
I know but is the yellow cart also the same and the rest not ?  A print
on the same matte  paper with 4000 PK and 4800 PK but from the same
printer will tell which has the higher pigment content.
Of course it could improve the results of the 4000 too if the PK of the
4800 has a higher Dmax as a result of the better balance in
gloss/pigmentation. Swapping chips + a chip resetter if needed. Probably
one has to find the right combination for a certain paper. Maybe it
requires other profiles + another paper setting etc for the Epson driver
even for the 4000 supported Epson papers, maybe inklimits and QTR for
B&W or another RIP for Color are needed.
SemiGloss paper Dmax will shift more to the middle between Gloss and
Matte Dmax when the PK inks get a more pronounced gloss quality.
One other thing has to be considered too. Gloss surfaces come in many
varieties (paper coating, Glop, varnish etc.) and some withstand time,
humidity, abrasion etc better than others. Dmaxes can drop by changed
gloss grades and then a higher pigmentation of PK will be better to keep
the density. A loss of transparency in the top layer will affect both
high and low pigmentation equal.
Ernst
2005-06-26 by kipduff
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
> >0% 0.1 0.1
> >10% 0.23 0.27
> >20% 0.35 0.39
> >30% 0.48 0.51
> >40% 0.63 0.65
> >50% 0.79 0.81
> >60% 0.97 1.00
> >70% 1.18 1.23
> >80% 1.47 1.55
> >90% 1.76 1.92
> >95% 1.86 2.08
> >100% 2.02 2.28
> >importance.
gloss in
Eboni
MIS UT
dark
far as
Probably
driver
keep
> Ernst
Guys:
I'm looking with great interest at your posts.  I just got a 4800 and
I mostly do BW.  I'm used to matt black so I substituted a 220ml MK
cart.  I see alot of people like Epson Premium semimatte paper so I'll
try it I think (don't see it as an option in my print dialog box
tho!).  I think I'm looking for the same thing you are.  My best work
is Tri-X 8 x 10 contacts on Agfa or Ilford's best- then dried on a
ferotype (gloss): has that deep silver 3D look.  So far gloss inkjet
media looks horible, so I've used mat.  I've been wanting to try to
get that deep look but sprays I've bought so far are invisible after
drying.  I want that laminated look.  Also, if you've ever messed with
colored pastels, when you spray fix them, they get deep and they
really pop.  Have you found something that will give these mat photos
that look?  They seem very absorbent and it seems they'd almost need a
primer.  I was thinking of dry-mounting on masonite and brushing on
laquer primer and final coats (unknown archival qualities).
Thanks, Kip.
