Re: [Digital BW] Advanced B&W - was 4800 v. UT7 1600 dpi scans
2005-06-28 by Bob Frost
Steve,
Just printed a Printer White Point Target from www.ZuberPhotographics.com
with and without the Highlight Point Shift box checked. Without it checked,
as you say, 255 is the same as the paper (Premium Glossy) and 254 can be
seen to be different. With it checked, the whole of the printable area
becomes glossier, and 255 is no different from that. The points 254 and
below are still distinguishable from 255, so the linearity of these lighter
points has been shifted. Presumably the highlight tonality slider does the
same sort of thing - haven't tried that yet.
The Printer Black Point Target is also useful for checking the black
end-point, which on this first print (using the Neutral/Darker default
setting for B&W) looks rather high. I'll try some more with the other four
Tone settings and the Shadow tonality slider.
As far as I am aware there is no BO setting (1 or 3) on the R2400.
For those who haven't seen the Advanced B&W settings on the R2400, there are
four Color Tones to choose from Neutral, Warm, Cool, and Sepia; five Tone
settings Darkest, Darker, Dark, Normal, and Light; and sliders for
Brightness, Contrast, Highlight Tonality, Shadow Tonality, and Max Optical
Density; as well as a Color Wheel for tinting, and the Highlight Point Shift
checkbox already mentioned. So there are plenty of adjustments that can be
made.
Bob Frost.
Ah. Thanks for pointing that out - I had simply overlooked it.  Yes the 4800
has the same check box.  I wonder how much the whites get clipped if you
check that box.  I'll have to play with it when I get a chance.  I have not
used it.  In the 256 step wedges I printed one can just see that there is
ink laid down at patch 254 and the difference between 252 and paper white is
easily discernible. The only issue I had ever noticed with gloss
differential on photo paper was when I had blown a small portion of an image
to pure white against a solid black background.  In that image, if I tilted
it severely (to an impractical viewing angle) I could see the gloss
differential between the paper and the surrounding ink and because it was in
the centre of the image it was noticeable.  I doubt I would find cause to
check that box - and I think I would rather control the clipping with a
curve or levels adjustment.  One would never use it for matte paper output.
I wonder if the images that Clayton saw were printed with this box
checked...
Steve,
Just measured the 255 and 254 patches with and without the Highlight Point
Shift box checked under Advanced B&W and the readings are (with i1 and
MeasureTool):-
Box unchecked
255    Lab    94.4    -0.2    -3.7
254    Lab    94.0    -0.1    -3.6
Box checked
255    Lab    91.3    -0.0    -3.6
254    Lab    90.2    -0.0    -3.5
Bob Frost.
