C86 - EZN horizontal banding
2005-07-03 by Jeff Medkeff
Some weeks ago, I picked up an Epson C86 and the MIS Ultratone EZN inks to fool around with black and white output. I'm following Paul Roark's recommended workflow at: http://home1.gte.net/res09aij/C86-EZ-UT-Readme.htm Specifically, I'm printing onto EEM with the C86 driver set to "best photo," with high-speed mode off. Last night I printed an image with a snowfield and some sky. Both are fairly broad areas with all the pixels nearly the same tone; snowfield very light, sky about middle gray. I'm getting horizontal banding in the printout. It is clearly visible by eye, though it is small. The banding is more easily seen in the sky, but is definitely present in the snow as well. The bands are about 0.75mm apart and are about equally thick. The file is 320 dpi. On a casual glance, most people I show the print to do not notice the banding. I ran a nozzle check (everything OK), and a head alignment check (everything OK). I printed the image again after this, just in case, with the same results. I then downloaded and installed QTR and printed the image at the same size on my 2200, just to see if somehow this was inherent to the image and I couldn't see it on the screen. The banding does not appear in that print. The C86 banding gives the impression of being the result of a bad dither pattern - perhaps the result of a buggy dither algorithm? Does anyone have any recommendations on how to proceed? I'm not seeing this on other images I've printed with the C86, but none of the other images have such broad areas of a single tonality. I've wondered whether the output file resolution is causing problems, and I might run that through a spline to increase the resolution and see what happens. But I thought I'd check here first. Thanks! -- Jeff Medkeff Eagle River, Alaska
