UT7 Inks+QTR+2200....Mysterious Problem Here
2005-07-05 by SteveZ
Today I just started using UT7 inks with QTR and I'm baffled by the
vertical banding I'm experiencing with the 2200 on
EEM. Now....when I use Paul Roark's worflow/curves with the Epson
Driver the banding disappears and the prints turn out fine.
Weird huh?
Is this a QTR problem? A 2200 problem? An inkset problem?
I believe I'm using the correct UT7 Curves for QTR as generously
provided to me by Daniel Staver but I wouldn't think that would be a
factor.
Any suggestions on how to correct this?
Re: UT7 Inks+QTR+2200....Mysterious Problem Here
I would also like to add that the prints made using QTR/UT7 Curves
turn out much richer and overall much better (except for the banding)
than using the Epson driver, which is really frustrating for me.
Why would this be?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "SteveZ"
> Weird huh?
a
> factor.
2005-07-05 by Clayton Jones
Hello Steve,
If the banding is broad and in opposite direction to head travel, try
up or down-rezzing the image about 20% and see if that makes any
difference.
Clayton
Clayton, the banding is mostly fine vertical (micro?) in nature
although I have experienced some of the broader banding as
well. I'm going to try up/down rezzing as you suggested and see
if it helps. Thanks!
SteveZ
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton
Jones" <cj@c...> wrote:
> Hello Steve,
the Epson
try
makes any
> difference.
> Regards,
> Clayton
