--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
<E.Dinkla@c...> wrote:
> and CMYK) made with the Eye-One and Colorport. The format of that
file
> should be Monaco Profiler but I can't make them with ColorPort as I
do
> not have an Eye One. Can't make the Mac version of the items above
> either as I have a PC.
> The above should probably work with other X-Rite and Gretag Macbeth
> meters as well with some adaptions.
> http://members.chello.nl/e.dinkla/ColorPort%2021%20step%20gray%
20patches.zip
> Ernst
What color space is the grayscale chart built in? Is it a CMYK space?
If it is, I can format it into something that color port can import
as a new custom chart, then people can just build their own target to
use any tool that works to measure it.(decided to just go ahead and
do it, it works) Just cut the text (between the lines) into a text
editor or database editor and save as a .csv (comma seperated value)
0,0,0,0
0,0,0,5
0,0,0,10
0,0,0,15
0,0,0,20
0,0,0,25
0,0,0,30
0,0,0,35
0,0,0,40
0,0,0,45
0,0,0,50
0,0,0,55
0,0,0,60
0,0,0,65
0,0,0,70
0,0,0,75
0,0,0,80
0,0,0,85
0,0,0,90
0,0,0,95
0,0,0,100
The same type applies to the RGB formated targets (but only 3 fields
and values from 0-255), if anyone wants to follow the above example.
I'll post a different type later, not sure if there is any
difference, but can't hurt.
Aside from not opening charts built in ColorshopX, I have found one
other flaw. It won't make a target from the Prinopen RGB files.
Colorport uses RGB levels from 0-255, Printopen uses levels from 0-
100. So for RGB profiles in Printopen, I still have some messing
around to get the data out of Colorport, and into Printopen. CMYK
charts import perfectly, and I then save the measurement as a CGATS
formated txt file. Printopen opens that CGATS file without issue.
This has made using Prinopen with my i1 effortless! Printopen 4 does
not support scanning mode with the i1, and Printopen 5 is about
$2000.00 away for the moment. Again, thanks for the link!!!!
