Refilling MIS Spongeless
2005-07-20 by Igor Wesdorp
I have just bought MIS spongeless carts for my 1160. Some things are
not quite clear yet, hope you will help me out:
1. Does the MIS Bottom Fill Adapter only have to be used the FIRST
time you fill a cart? Or every time? My guess would be only the first
time, to remove initial air pockets. That is, if you can leave the
carts inside the printer when refilling? Or do you have to take them
out each time? If so, why?
2. How do you know when to refill which compartiment in the color
cart? Or do you have to refill all three every time the
out-of-ink-light goes on?
Thanks!
I g o r
Re: Refilling MIS Spongeless
2005-07-20 by Steven Karafyllakis
Hello Igor;
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Igor Wesdorp"
are
first
them
If you take them out each time you can check for air pockets, and
visually check the ink level in each compartment; you don't want to
let the head run dry, it could damage it. If you want to avoid the
initial fill cycle, you might try momentarily turning of the printer
just after re-inserting the full cart. With some printers this works.
Steve Karafyllakis
> Thanks!
> I g o r
Yes, but is it not so that by taking them out, you create new air
pockets in the ink outlets (I suppose this is were these air pockets
arise). Thus, is it not better to leave the carts in the printer while
filling, and monitoring the ink level by looking from above?
And do you, as with pre-filled carts, use the "out-of-ink-light" as an
indication that you have to do a refill?
Btw, Thank you, Steven.
I g o r
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
Karafyllakis" <steve@s...> wrote:
> Hello Igor;
> are
> first
> them
> Steve Karafyllakis
> > Thanks!
> > I g o r
Re: [Digital BW] Re: Refilling MIS Spongeless
2005-07-20 by Steve Kale
You need to reset the chip.  I believe this can only be done by taking the
carts out.  At this point there is a real risk that air gets into the area
around the poppet valve which must then be removed with the bottom fill
adaptor.
> From: Igor Wesdorp <iwesdorp@...>
> Date: Wed, 20 Jul 2005 15:59:19 -0000
> Subject: [Digital BW] Re: Refilling MIS Spongeless
> I g o r
2005-07-20 by dfaprinting
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
taking the
the area
fill
> adaptor.
Depends on the printer. Some printers can use the sscg software to
reset the chips while they are still in the printer. Other printers
can only freeze the ink counter, and some others don't work at all.
The 1160 has no chip, you can reset it by lifting two little levers.
So I don't have to take the carts out for that reason. Still keeps me
wondering: isit not so that by taking the carts out, you create new
air pockets in the ink outlets (I suppose this is were these air
pockets arise). Thus, is it not better to leave the carts in the
printer while filling, and monitoring the ink level by looking from above?
I g o r
2005-07-20 by Johnny Eades
There is a utility that will reset the ink levels/chip called
sscerve.exe. If you'll email me offlist, I'll send it. It's about
750K in size.
Your friend in Photography,
Johnny
taking the
the area
fill
> adaptor.
2005-07-21 by Igor Wesdorp
Thank you, but I already found sscerve. But please, anyone, grant me
an answer to this:
Is it not so that by taking the carts out, you create new
Thank you.
I g o r
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Johnny Eades"
> 750K in size.
> Johnny
2005-07-21 by Johnny Eades
Igor,
In my printer, and I imagine all Epsons, when I raise the hold-down
on the cartridge I wish to refill; the cartridge itself is lifted off
the posts that hold open the poppet valves. This effectively closes
the poppet valve but does not allow air to flow into the cartridge.
Refilling outside the printer would seem to be much cleaner than
trying to maneuver in such a close space. When the cartridge is re-
inserted into the printer and over the posts, if there is any air in
the post, it's removed when you use the utility to tell it to reset
the counters on the cartridge replaced; because the printer will do a
head cleaning routine when the printer is restarted.
As far as waiting for and out of ink light to start flashing, I
simply keep an account of how many 8 x 10 sheets I print. If that is
not reasonable, simply open the printer and see which ink chamber
needs ink. This is a good reason to use MIS spongeless carts because
they will allow your to see the ink level visually. Also the sscerve
utility will let you see onscreen the ink levels too.
Johnny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Igor Wesdorp"
> an answer to this:
above?
an
> Thank you.
> I g o r
> > 750K in size.
> > Johnny
