Fw: [EPSON_Printers] CRT 22" monitors
2005-08-14 by dschiemann
Any recommendations and suggestions on a CRT 22" monitor would be most
appreciated.  Thanks.
Donald
To: "EPSON PRINTERS" <EPSON_Printers@yahoogroups.com>
Sent: Friday, August 12, 2005 2:12 PM
Subject: [EPSON_Printers] CRT 22" monitors
>I apologize for posting a request on a subject that has been discussed many
> times, but I must make a decision on the purchase of a CRT 21-22" monitor
> and am confused about the choice.  I thought the LaCie Electron Blue IV
> 22"
> was the best choice, but read a negative review.  The Mitsubishi Diamond
> Pro
> 2070SB-BK with or without Spectraview is apparently unavailable, and also
> would probably exceed my budget of something around $800 or less.  Does
> anyone have an opinion on the NEC Multysync FE2111SB-BK?  Your comments
> and
> recommendations will be most appreciated.
> Donald
> Also try our Canon Printer list at:
> http://groups.yahoo.com/group/Canon-printers
> our HP Printer list at:
> http://groups.yahoo.com/group/HP-inkjet
> and, our Lexmark Printer list at:
> http://groups.yahoo.com/group/lexmark-inkjet
Re: Fw: [EPSON_Printers] CRT 22" monitors
2005-08-14 by Tony Bonanno
Hi Donald,
I'll venture an opinion here.  I was in the same situation as you in
that I needed to replace my 21" Trinitron graphics CRT due to aging
color guns, etc.
The bottom line:  none of the 22" monitors I purchased or did a hands
on workflow with (Mitshibushi 2070SB - two of them, IBM top of the
line equivalents - two of them, Lacie, etc.) - all the top rated
models, except I did not try the Sony Artisan, had serious color cast
problems in my studio environment.  I got the impression that the
manufacturers were cutting corners as they were phasing out every one
of these models.  When I tried to send the second 2070SB back to the
manufacturer, they told me they couldn't replace it as they had
discontinued production. The Sony Artisan is out of production also.
Color mgmt guru Andrew Rodney I believe went through 3 Lacies and they
all had color cast problems.  Another photographer colleague of mine
bought a Lacie, was happy with it for about 4 months and it developed
color cast problems.  He sent it back and got one that was worse.
I have to tell you packing up those heavy anchors and shipping back
and forth trying to get a good one is something I don't want to ever
deal with again.
I'm back to using my old Sony Trinitron monitors.  They were getting
worrisome, but they still calibrate with my Monoco OpticXR.  I was
trying to be proactive, but the fact is, I don't think there is much
out there in CRT's that you want to sink money in.  Even if you find a
good one, good luck getting any factory support.  They'll just send
you a refurb which may or not be as good as what you had.
I realize that my experience may be atypical (I hope so), but I've
decided to replace the Sonys with LCD monitors - possibly the new
large Dell models.  I did a brief trial with a Samsung 213T (21") and
actually was fairly pleased with it.  I think the newer models will be
better though.  The better ones are handling black points and tonal
transitions much better than before.
Good luck!
Tony
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dschiemann"
> Donald
> From: "dschiemann" <DSCHIEMANN@p...>
discussed many
monitor
Blue IV
> > 22"
Diamond
> > Pro
and also
 Does
comments
> > and
> > Donald
> > Yahoo! Groups Links
2005-08-14 by dfaprinting
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tony Bonanno"
and
be
The Apple Cinema displays are really nice, now that they use a
regular DVI connection, they work with any DVI capable video card.
The Samsung units are also really good, seems Samsung is a real
pioneer in the LCD arena. They claim great things with their newer
organic LCD displays, though I haven't seen any of those yet. Eizo
makes a top rated LCD, it of course costs a lot. NEC/Mitsubishi are
really nice too and offer the same 3 year warranty that they did with
the CRTs. WHatever you try/buy you probably want to go with a multi
frequecy (Multisync) unit with a DVI connection. DVI makes a big
difference.
Re: [Digital BW] Fw: [EPSON_Printers] CRT 22" monitors
2005-08-14 by Eric Ashworth
Hi Donald,
While I am no expert on CRT monitors, I do own a Mitsubishi Diamond
Pro 2070 SB.  And, when I purchased it, I had done a bit of homework
on the NEC/Mitsubishi monitors.  Essentially, the 2070 SB and the
FE2111 SB are the same monitor, simply marketed under the NEC or
Mitsubishi names, respectively.  One of the few differences I found
was that the FE2111 does not support the 2048 x 1536 resolution (not
sure why), but that doesn't really matter (that is unless you need it
for some reason) since the recommended resolution for both monitors
is 1600 x 1200.  Also, the FE2111 does not have a built in USB hub.
Otherwise, they have the same picture tube, and offer essentially the
exact same features.  If you'd like to check this yourself, you can
go to NEC's website and look up their non-current monitors, then
compare the user's manuals.
I did want to mention that by doing a search on froogle.com I located
three online suppliers that were still offering the 2070 SB, and the
lowest price was around $690 USD, the only drawback is that I've
never heard of any of the three companies before, I guess, buyer
beware.  As far as the price goes, if they charge shipping, it'll be
a hefty charge, as the monitor is approximately 65 lbs.  I do have to
say that you'll probably have difficulty locating the FE2111 SB as
well considering it has been discontinued as well.
Now, as to recommendations, mind you this is based on my subject
evaluation, I would highly recommend either monitor, as I have been
exceptionally happy with mine.  Probably the best feature offered
with these, is the ability to use the downloadable software, Naviset,
to control the RGB guns separately.  In conjunction with reasonably
capable color management software and a colorimeter, the color
accuracy I've achieved is nearly perfect (I'm using the Spyder2PRO
system).  As far as rendering text, the monitors definitely rank
pretty low as they seem to have been optimized for graphics, and
generally text is somewhat soft.  So, if you were wanting to use it
for any sort of graphic design layouts, that might be something to
consider.  Otherwise, it hasn't been an issue for me.
Well, good luck, and hope this helps.
Best regards,
Eric
www.ericashworth.net
> Donald
> From: "dschiemann" <DSCHIEMANN@...>
> discussed many
> monitor
> Blue IV
> > 22"
> Diamond
> > Pro
> and also
> less.  Does
> comments
> > and
> > Donald
One last note, the response in the "shadows" of my images has been
one of the reasons for my satisfaction with the monitor.  The
separation of values is quite readable and therefore a more accurate
reflection of my final print.  I had considered an Apple Display, but
was rather disappointed with their performance in the darker values.
Once again, my subjective evaluation, so take it with a grain of salt.
Eric
Re: [Digital BW] Re: Fw: [EPSON_Printers] CRT 22" monitors
2005-08-14 by Elwood Spedden
Donald
I have been using the new Dell 24" wide model for
several months and have been very happy. I calibrate
it using the eye one photo and calibrate my printers
with the same software. When I use the soft proofing
feature of PS CS2 I get a very good correlation
between what I see and what I get........Not 100% but
certainly close enough to keep the number of proofs to
a minimum.
While Dell is not often lumped in with the "high end
monitors" it is the opinion of many now that their
offerings are very competitive. (For example, the
Apple 21" Theater display and the Dell equivalent use
exactly the same module from LG electronics)
Good Hunting
Woody Spedden
--- Tony Bonanno <tbonanno-ranger2004@...>
wrote:
Hi Donald,
situation as you in
due to aging
color guns, etc.
or did a hands
IBM top of the
top rated
serious color cast
impression that the
2070SB back to the
they had
production also.
Lacies and they
colleague of mine
and it developed
was worse.
shipping back
don't want to ever
deal with again.
They were getting
OpticXR.  I was
there is much
Even if you find a
They'll just send
had.
so), but I've
possibly the new
213T (21") and
points and tonal
Good luck!
Tony
"dschiemann"
> Donald
has been
discussed many
of a CRT 21-22"
monitor
LaCie Electron
Blue IV
> > 22"
The Mitsubishi
Diamond
> > Pro
and also
 Does
FE2111SB-BK?  Your
comments
> > and
> > Donald
> > Yahoo! Groups Links
Please visit the Group Homepage to check the Files,
and other resources as they are often being updated.
If you wish to receive no emails or just a daily
digest, or you wish to unsubscribe, please edit your
Membership preferences by visiting this same page.
- As threads develop, trim off excess portions of
earlier messages to keep them short.
- Good manners are required at all time. No personal
attacks or flames. Hostile, aggressive or
argumentative users may be removed from the membership
without notice.
- Keep your posts and threads related to the group
topic of digital B&W printing. Users who persistently
make off-topic posts may be removed from the
membership.
- By posting on this forum you agree to abide by the
group rules and guidelines, and to abide by the
actions and decisions of the group Owner and
Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in
the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE
DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY
UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd
OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING
BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN
IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE
PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY
OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE
INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO
GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING
TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
  YAHOO! GROUPS LINKS
    Visit your group "DigitalBlackandWhiteThePrint" on
the web.
    Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
2005-08-14 by Scott McLoughlin
Since this is a B&W forum, do other forum members find that grain in
scanned B&W images seems accenctuated by LCD monitors, and not so
by CRT monitors?   Or am I seeing things?  Or is it a quality of LCD monitor
issue or what?
I'm not in love with the bulk of my aging Dell Trinitron, but this issue
has
bothered me in the past.
Thanks.
Scott
> Good luck!
> Tony
2005-08-15 by Eric Ashworth
I've definitely experienced the same perception.  If I'm working from
negatives, I definitely prefer working on a CRT as I feel it gives me
a little bit better sense of the values and textures in the image.
Also, often when I'm sharpening an image right before printing, I
find that I have to increase the sharpening beyond what looks good on
my CRT to get a print equivalent to my expectations.  And, if I view
the same image on my LCD, it's even worse, making it difficult to
guestimate the level of sharpening needed.  From what I've read, that
is primarily due to the fact that the image your viewing is set to 72
ppi, whereas if you're printing high res output, your actual
resolution is at least 4 times that.  And, since LCDs generally are
more "crisp," this effect is exaggerated.  But, since it seems that
prosumer CRTs are generally disappearing from the market, maybe it's
just something we'll have to get used to.
Eric
> LCD monitor
> issue or what?
> issue
> has
> Thanks.
> Scott
