missing jets on 2200
2005-08-16 by Jerry Blanton
Hi, Hoping the sage wisdom of the 2200 users in this group can help... I have a new problem on a several year old Epson 2200. A while back I was using MIS UT7 inks and I suddenly developed some banding that wouldn't clear using the tips in the knowledge base. Ultimately I deciced to switch back to Epson UC inks and after a few cleanings/purge prints things were fine. I use the printer every so often but certainly not every day. I last used it a week ago and it was fine. I went away for nearly a week (and while I was gone the temp soared to 100 degrees) and when I went to print I had horrific banding and it looks like Cyan has stopped printing entirely. I had some other carts that were running out of ink so I replaced those (with Epson UC). At this point, Cyan and Lt Cyan do not appear to print at all...Lt Black barely does. All others band as well. I've tried all the clean/clean/clean print clean/clean/clean tips. Is my only recourse at this point to use the cleaning fluid on the dump sponge? thanks Jerry
