RE: [Digital BW] Fade test -- non-OBA papers v. EEM, 4800 & UT7
2005-08-17 by Timothy Atherton
> Message: 16 > Date: Tue, 16 Aug 2005 23:21:37 -0700 > From: "Paul Roark" <paul.roark@...> > Subject: Fade test -- non-OBA papers v. EEM, 4800 & UT7 > > I had 2 non-OBA papers in this fade test -- PermaJet Alpha and Premier Art > Fine Art Hot Press 205. As one would expect, the non-OBA papers are much > more stable in the paper color. Although EEM did very well in terms of > fading, the yellowing of the paper may also have significantly > affected even... Paul, what are the parameters and set-up for your fade testing? I've forgotten tim a
2005-08-17 by Paul Roark
Briefly, I use a compact fluorescent light (see http://www.lightsofamerica.com/megalite.htm) in a 10" aluminum reflector with clips holding test patches along the rim. The clips also hold the reflector 1" above a white Formica counter, so that air can enter there and be vented out the top, near the light base, where I've drilled vent holes. To help assure evenness of light, I rotate the reflector 1/8 turn, 7 times during the 600 hours. (If you look at the light you'll see why the rotation pattern.) I'll try to get a picture on the web at some point. That shows how the setup looks. Paul www.PaulRoark.com
> -----Original Message----- > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Timothy > Atherton > Sent: Wednesday, August 17, 2005 9:29 AM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: RE: [Digital BW] Fade test -- non-OBA papers v. EEM, 4800 & UT7 > > > Message: 16 > > Date: Tue, 16 Aug 2005 23:21:37 -0700 > > From: "Paul Roark" <paul.roark@...> > > Subject: Fade test -- non-OBA papers v. EEM, 4800 & UT7 > > > > I had 2 non-OBA papers in this fade test -- PermaJet Alpha and Premier > Art > > Fine Art Hot Press 205. As one would expect, the non-OBA papers are > much > > more stable in the paper color. Although EEM did very well in terms of > > fading, the yellowing of the paper may also have significantly > > affected even... > > > Paul, what are the parameters and set-up for your fade testing? I've > forgotten > > > tim a > > > > > Please visit the Group Homepage to check the Files, and other resources as > they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to > unsubscribe, please edit your Membership preferences by visiting this same > page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages to keep > them short. > - Good manners are required at all time. No personal attacks or flames. > Hostile, aggressive or argumentative users may be removed from the > membership without notice. > - Keep your posts and threads related to the group topic of digital B&W > printing. Users who persistently make off-topic posts may be removed from > the membership. > - By posting on this forum you agree to abide by the group rules and > guidelines, and to abide by the actions and decisions of the group Owner > and Moderators. See "Group Topic, Rules and Guidelines" in the Files > section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO > YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN > ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE > OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > PRINT YAHOO GROUP. > > Yahoo! Groups Links > > > > >
