Moab Kayenta: any numbers available?
2005-08-17 by Steven Karafyllakis
Hello Moab fans,
I know this has been asked before, but I don't remember the answer-are
there any fade-test numvers available for this paper? Or any of their
papers?
Thanks
Steve Karafyllakis
Re: [Digital BW] Moab Kayenta: any numbers available?
2005-08-18 by James Irelan
On Aug 17, 2005, at 4:54 PM, Steven Karafyllakis wrote:
> Hello Moab fans,
> papers?
> Thanks
> Steve Karafyllakis
I can tell you that Entrada printed with Lyson Fotonics fades after
several months to maybe a year, max.  I printed a series of art
posters for a friend, with the admonition that she put them behind
glass.  For the folk-art look of them, however, she declined, and
hung them without glass on her wall, no direct sunlight.  They are
quite noticeably faded now.  I believe this to be much more a
function of the dye ink, though,  than the paper itself.  I have some
other prints out open printed with UCs on various matte art papers
that still look fine after a few years.
James
2005-08-18 by Steven Karafyllakis
Thanks, James- I agree it was most likely the dye inks causing the
rapid fade. Is Entrada a cotton paper? I know Kayenta is Alpha-
cellulose, I'm just wondering if it is more reliable than EEM as a
cheap proofing paper. It would be nice to have something you could
keep or give away without worrying about it turning yellow  down the
road.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, James Irelan
> > Hello Moab fans,
answer-are
their
> > papers?
> > Thanks
> > Steve Karafyllakis
after
behind
are
some
papers
> James
2005-08-18 by Clayton Jones
Steve,
Yes, but it flakes terribly.
> road.
Moab says it's acid/lignen free so it's probably fine.
Clayton
It sounds like Clayton has had more problems with flaking on Entrada
than I have.  I have had some.  I stopped using my favorite paper,
Torchon, or Riviera (Mediastreet) because of the flaking problem,
which I still believe is not true flaking, but rather a situation
where the ink separates like a bubble popping, leaving a spot.  I
have never seen an actual physical flake, and I've looked very
carefully.  I routinely brush off my papers before printing with a
drafting brush.  I'd go back to Riviera immediately if the "flaking"
problem were solved.
James
