Re: Re: Genuine Fractals (and Photokit Sharpener workflow)
2005-08-21 by Christer Rosewelll
Bruce,
I also have come to similar conclusions - I'm on Macs so don't use
Qimage or Shortcut Photozoomm but have Genuine Fractals (haven't used
it for years) but use Photokit Sharpener all the time.
I do follow the recommended workflow, do the Pre sharpening, the
Creative sharpening (after I've done all the other corrections I deem
necessary) and then after upsizing in Photoshop as the last step I use
the Output sharpener. For those of you not familiar with Photokit
Sharpener - the Output sharpener is applied as the last step before
printing and it applies sharpening depending on what kind of printer
you output to, matte or glossy paper and what resolution the file is
at.
I can't recommend this program enough - it is great - I've had, like
Scott Jones described in another post,  photographers and collectors
standing in front of my prints, begging me to tell them which ones of
the prints were film or digital - or if they were either... They simply
couldn't tell...
Christer
			Christer, AKA Christer Rosewell
			  http://www.ChristerArt.com
		  	   3.7 million visitors to date..
On Aug 21, 2005, at 1:19 AM,
>    From: "btvarner" <bthomasv@...>
> Subject: Re: Genuine Fractals
> I have been following this thread with great interest & decided to do
> a little test myself.  I must say that the results seem to be the
> opposite of what most here seem to have found.
> I down loaded & installed the latest demo versions for both Qimage &
> Shortcut Photozoom Pro then did a comparison of prints from the same
> image.  Unless someone can tell me what I might have done wrong, my
> results indicate that neither product produces a better image what I
> am already doing.  Follow and see:
> Test images produced by all three products (Qimage, Photozoom,
> Photoshop) were printed in color (I did not want to introduce another
> variable into the mix, aka QTR) using my Epson 2200 and OEM inks.
> Also note that the Raw image I picked was from a Canon 10D & 12x18 is
> about the absolute maximum size from this camera on my Epson 2200.
> My current workflow in Photoshop CS2:
> Canon Raw to Tiff,
> Applied initial Capture sharpening using Photokit Sharpener Pro Plug-
> in,
> Crop as desired,
> Create adjustment layers or layer masks as required,
> Adjustments to Levels, Curves, Hue/Saturation, Color Balance, etc�
> [At this point I saved the image to four files, one for each products
> print]
> Re-sampled 1st image to 12x18 at a resolution of 360 in Photoshop
> using bicubic,
> Applied creative sharpening using Photokit Sharpener Pro,
> Printed using "SP220 EnhancedMatt 2880PK.icc" printer profile,
> All print driver corrections turned off
> Qimage workflow:
> Opened 2nd image from above in Qimage,
> Re-sampled image to 12x18 apparently at 720 resolution using Pyramid,
> Saved to another file & closed Qimage,
> Opened this Pyramid re-sampled image in Photoshop,
> Applied Creative Sharpening using Photokit Sharpener Pro,
> Saved file & again opened in Qimage,
> Selected this image & printed,
> took nearly 1 hour for Qimage to do its thing & for the data to
> spool!!!!!!
> Sharpening in Qimage appeared to be off,
> This print was wayyyyyy over sharpened, so��.
> Picked the 3rd image in Qimage and just resized as above & printed.
> Photozoom workflow:
> Opened 4th image from above I Photozoom,
> Re-sampled image to 12x18 apparently at 720 resolution using S-spine,
> Left Photozoom Unsharp Mask on as re-sampled image appeared to be way
> to blurry,
> Printed.
> Results of the four 12x18 prints:
> Photoshop print � Best by far.  Sharp & clear.  Admittedly could
> be sharper in some areas of the image but normally I can go back into
> Photoshop and re-apply Creative Sharpening using Photokit Sharpener
> Pro to just that area & improve image.
> Qimage print � 1st Qimage print looked absolutely phony because
> of over sharpening.  Apparently you cannot apply your own sharpening
> in another tool and then go back & print in Qimage and obtain the
> correct sharpening.  2nd Qimage print.  Sharper in certain areas of
> the image, but still over sharp in others.  Enough that the image did
> not look real.
> Photozoom � Image was not nearly as sharp as either of the other
> two.  I attempted to sharpen based on the products previews of my
> image but no mater how sharp I attempted to make the image on screen,
> it did not look sharp.  I settled on about half way up for the
> sharpening settings in Photozoom.
> So, am I way off base here?  Just not using Qimage & Photozoom
> correctly?  I know I am new to both products but I do not see even a
> savings in time from using these tools.
> Puzzled,
> Bruce Varner
> http://brucevarner.com/
Re: [Digital BW] Re: Re: Genuine Fractals (and Photokit Sharpener workflow)
2005-08-21 by Elwood Spedden
A while back I remember reading a comparison of
Genuine Fractals and Extensis Pixel Smart Scale. If I
recall correctly, the conclusion was that Smart Scale
was every bit as good as GF without all the issues of
proprietary save format.
Does anyone here have experience with SmartScale?
Woody Spedden
2005-08-21 by Bill
I think you're referring to a magazine review where Smart Scale seemed to do the best job - may have been Popular Photography.  Anyway, I've used SS to upsize my D70 shots to 20x30, and they printed flawlessly.
Bill
Woody Spedden
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
SPONSORED LINKS
Digital photography technique Digital photography Photography school Professional digital photography Stock photography
YAHOO! GROUPS LINKS
    Visit your group "DigitalBlackandWhiteThePrint" on the web.
2005-08-21 by btvarner
Thanks Christer, Peter, Bruce, and the others who have responded!  At
the moment I have to stay with the fact that for me, Photoshop CS2 &
Photokit Sharpener Pro seem to produce the best results for the size
& type of printing I have been doing.  Having said that, I did get up
this morning with a fresh outlook and set down to give Qimage another
try.
I changed the "Interp" settings in Qimage from Pyramid-5 and
experimented with the other settings.  For this same image I finally
settled on Vector with a default (5) setting.  This produced an image
that was better then my "Photoshop CS2 & Photokit Sharpener
Pro"
method on parts of the image and not as good on other portions of the
image.
It looks like the large number of setting options are something that
I will have to do further experimenting with.  Some of the other
abilities that Qimage has involving multiple images on a page and the
ability to bypass Epson's limit of 44" print length are
things I
could use if the sharpening issues can be resolved.
The one thing that I love about Photokit Sharpener Pro is its ability
to selectively sharpen edges in only that part of the image that
requires the enhancement.  I guess I will try an experiment to only
sharpening in Photoshop/Photokit Sharpener the parts of an image that
require the very most attention and do absolutely no other sharpening
on the image.  Then open in Qimage to size and print.
I guess I am so used to having the ability to sharpen exact parts of
an image to different degrees, I can't do with out it.
If someone out there uses Qimage regularly, can you tell me if Qimage
has the ability to only apply sharpening to parts of an image or at
least different levels of sharpening to different areas??  Thanks!
You know, I guess I am getting lazy in my old age but it sure seems
that there should be a better way to learn a new piece of software
then having to re-invent the wheel all over again.  I know I am not
the first one to attempt this.
Bruce Varner
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Christer
Rosewelll <christerart@m...> wrote:
> Bruce,
used
deem
use
printer
is
> at.
like
collectors
of
simply
> couldn't tell...
> Christer
Re: [Digital BW] Re: Genuine Fractals (and Photokit Sharpener workflow)
2005-08-21 by Ernst Dinkla
That would be the way to do selective sharpening. Qimage can't as far as
I know and being essentialy a printer program it isn't intended for that
work either. If you sharpen the image selectively or entirely so it
looks sharp on the screen then I wouldn't take the default (5) print
sharpening of Qimage but the 2 at most.
Ernst
2005-08-21 by Brian Ellis
There's a sharpening method described in the tutorial section of Luminous
Landscape that does the same thing and is free. It may not be as good in
other respects as Photokit but it does do that. It also doesn't require
converting to rgb, which Photokit did when I tried it a year or so ago. Does
it still require that conversion?
Sent: Sunday, August 21, 2005 3:12 PM
Subject: Re: [Digital BW] Re: Genuine Fractals (and Photokit Sharpener
workflow)
Ernst
page.
them short.
the membership.
Yahoo! Groups Links
2005-08-21 by Carl Schofield
Still rgb only as far as I know.  PK folks said they were working on
a 16 bit B&W version, but guess it is still on the back burner.  I
use the deadman sharpening actions for B&W.
> Luminous
> good in
> require
> ago. Does
> From: "Ernst Dinkla" <E.Dinkla@...>
> workflow)
> far as
> that
> Ernst
