4800 and QTR?
2005-08-26 by scott_now_coming
Does QTR support the Epson 4800? And, is it possible to print on matte papers without using "Black"? I need to keep PK in my printer for printing color on glossy, luster, .... Went to the QTR website, but couldn't find the answer to my 2 questions. Thanks, Scott
2005-08-26 by Steve Kale
> From: scott_now_coming <scott_now_coming@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Fri, 26 Aug 2005 04:36:37 -0000 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: [Digital BW] 4800 and QTR? > > Does QTR support the Epson 4800? Yes. I have done curves for HPR, PJ Omega, PJ Alpha and EAM. > > And, is it possible to print on matte papers without using "Black"? > > I need to keep PK in my printer for printing color on glossy, > luster, .... No you need the black. But it only costs about £19 to swap K inks. If you have come from the 21/22/2400 world think about this: a 220ml ink cartridge costs £47, a 21/2200 cartridge about £10. The 220ml cartridge takes about 18x the amount of ink in the 21/2200 cartridge. (I'll let you do your own calculations in your own currency.) Changing the K ink is rounding error and easily recouped from your ink cost savings - unless of course you change it for every print. You don't buy a Ferrari and then worry about your petrol bill...
2005-08-26 by John Moody
There is a UC-NoBlack-neutral profile for the 2200. You could do the same thing for the 4800, but with 2 light inks rather than just one. It mixes light cyan and light magenta with the light gray to make the black. You could also try mixing full strength cyan and magenta, since the 4800 has two light grays, that could be better; I have no idea, it would have to be tried. The curve description is below. Note that the black ink is limited to 0, so it is not used. Best regards, John Moody # # quadtone curve descriptor file # # # the printer name # the curve name # no spaces or special characters, except - or _ (dash or underscore) # CALIBRATION=NO GRAPH_CURVE=NO # # number of inks must be 4, 6, or 7 # the ink limits are percentages # usually they are all the same but they can be individually set # N_OF_INKS=7 DEFAULT_INK_LIMIT=100 LIMIT_K=0 BOOST_K= LIMIT_C=0 LIMIT_M=0 LIMIT_Y=0 LIMIT_LC=25 LIMIT_LM=25 LIMIT_LK= # # Describe Usage of each Ink: K,C,M,Y,LC,LM,LK # All Inks of Printer must be listed # # # Gray Partitioning Information # N_OF_GRAY_PARTS=2 GRAY_INK_1=K GRAY_VAL_1=100 GRAY_INK_2=LK GRAY_VAL_2=100 GRAY_INK_3= GRAY_VAL_3= GRAY_INK_4= GRAY_VAL_4= GRAY_INK_5= GRAY_VAL_5= GRAY_INK_6= GRAY_VAL_6= GRAY_INK_7= GRAY_VAL_7= GRAY_HIGHLIGHT=4 GRAY_SHADOW=8 GRAY_GAMMA=1 GRAY_CURVE= # # Toner Partition Information # N_OF_TONER_PARTS=0 TONER_INK_1= TONER_VAL_1= TONER_INK_2= TONER_VAL_2= TONER_HIGHLIGHT=2 TONER_SHADOW=2 TONER_GAMMA=1 TONER_CURVE= # # Unused Inks # N_OF_UNUSED=2 UNUSED_INK_1=C UNUSED_INK_2=M UNUSED_INK_3= UNUSED_INK_4= # # the following is a special UltraChrome ink flag it copies the # light-black curves to the light-cyan, light-magenta and yellow inks. # this insures that the LC and LM inks are used to directly neutralize # the color of the light-black. # the color balance of inks is controlled by the LIMIT_... values above. # UC_NEUTRALIZER=YES LINEARIZE="0.039 0.073 0.104 0.145 0.192 0.234 0.299 0.353 0.417 0.485 0.541 0.613 0.690 0.763 0.856 0.937 1.049 1.178 1.322 1.492 1.770 " Best regards, John Moody
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of scott_now_coming Sent: Friday, August 26, 2005 12:37 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] 4800 and QTR? Does QTR support the Epson 4800? And, is it possible to print on matte papers without using "Black"? I need to keep PK in my printer for printing color on glossy, luster, .... Went to the QTR website, but couldn't find the answer to my 2 questions. Thanks, Scott [Non-text portions of this message have been removed]
2005-08-26 by Stephen Billard
The 4800 is supported, but the only curves are for the MK ink. You would have to create your own curves using PK if you are not happy with the results using MK curves. -Stephen www.sbillard.org/Stephen
> -----Original Message----- > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On > Behalf Of scott_now_coming > Sent: Thursday, August 25, 2005 9:37 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] 4800 and QTR? > > > Does QTR support the Epson 4800? > > And, is it possible to print on matte papers without using "Black"? > > I need to keep PK in my printer for printing color on glossy, > luster, .... > > Went to the QTR website, but couldn't find the answer to my 2 > questions. > > Thanks, > > Scott >
Thanks Steven and others that have replied and answered my questions. : > ) Scott --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Billard" <stephen@s...> wrote: > The 4800 is supported, but the only curves are for the MK ink. You would have to > create your own curves using PK if you are not happy with the results using MK > curves. > > -Stephen > www.sbillard.org/Stephen > > > > -----Original Message----- > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On > > Behalf Of scott_now_coming > > Sent: Thursday, August 25, 2005 9:37 PM > > To: DigitalBlackandWhiteThePrint@yahoogroups.com > > Subject: [Digital BW] 4800 and QTR? > > > > > > Does QTR support the Epson 4800? > > > > And, is it possible to print on matte papers without using "Black"?
> > > > I need to keep PK in my printer for printing color on glossy, > > luster, .... > > > > Went to the QTR website, but couldn't find the answer to my 2 > > questions. > > > > Thanks, > > > > Scott > >
