> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
> <paul.roark@v...> wrote:
> > You'll notice that I generate black with the 2 dark grays. It
> generally is
> > better than at least the old PK. I think there are several reasons for
> > this. It allows the tone to be controlled, it has less gloss
> differential,
> > and perhaps 2 jets firing gets better coverage.
> > One reason the MIS PK did not do well was that it dulled down too
> much. My
> > mixing indicates that the old MIS PK actually had more pigment in it
> than
> > the Epson PK. In fact, it probably had too much pigment. That may have
> > contributed to the dulling down problem and be the reason the dark
> grays did
> > better -- they have more base that does a better job of coating the
> carbon.
> > This is one area where the Epson PK acrylic-coated particles paid off
> > significantly.
> > Some of us have tried the Epson PK in an otherwise MIS UT inkset.
> However,
> > what we've found is that the transition from the un-coated to coated
> > particles is visible and gives a rough look to the shadows.
> > The new MIS PK appears to significantly address the dulling-down
> problem.
> > The new base, in effect, coats the particles much better. I have
> not had an
> > opportunity to test the new PK on various papers, but samples I have
> appear
> > to retain their gloss quite well.
> > Paul
> > www.PaulRoark.com
> > > -----Original Message-----
> > > From: DigitalBlackandWhiteThePrint@yahoogroups.com
> > > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
> > > Jonathan Traupman
> > > Sent: Thursday, September 08, 2005 11:27 PM
> > > To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > > Subject: [Digital BW] Weak blacks with UT7 PK and PKN
> > > I've been doing B&W printing with a 2200 and the UT7 inks for about a
> > > year now and have been getting great results on matte papers with
> > > Eboni black. I drive the printer with Quadtone RIP and build most of
> > > my paper profiles myself with a Noritsu DM-201 densitometer.
> > > However, I've had very limited success with printing on glossy and
> > > semi-gloss media. The biggest problem I've encountered is that the MIS
> > > Photo Black ink is simply not very dense.
> > > For example, I'm trying to create a QTR profile for Epson Premium
> > > Semigloss paper. If I print the QTR ink limit file in calibration mode
> > > with all limits set to 100%, the density of the 100% Photo Black patch
> > > is only around 1.9. This is weaker than the densities of the Dark Warm
> > > Gray (2.1) and Dark Cool Gray (2.2) 100% patches. I've actually gotten
> > > better results from profiles that just use the gray inks than from
> > > ones that use PK and the grays, though neither looked particularly
> great.
> > > I recently ordered a bottle of the "experimental" PKN Photo Black
> > > Neutral ink since MIS claims it has a higher Dmax than regular PK.
> > > However, I neither noticed nor measured any appreciable increase in
> > > density, at least on the Premium Semigloss paper. It is a more neutral
> > > black, however.
> > > So, is this normal behavior for the MIS Photo Blacks? With the Epson
> > > UC Photo Black, I routinely got densities of 2.2+ with this paper. It
> > > just seems odd that MIS's Photo Blacks would be this weak, when their
> > > grays clearly indicate that they can make a denser ink.
> > > My search through the archives yielded little info on this topic, but
> > > it does seem that densities around 1.9 are what people have reported
> > > in the past for these inks. Is this true across papers, or is the
> > > Premium Semigloss just a particularly bad choice for the MIS inks?
> > > The only potential problem that I can imagine with my setup is that I
> > > have put the PK ink in a light black cartridge and am using it in that
> > > position, because QTR allows me to control which black to use in
> > > software, and I have no need for the "Custom Light Black" that usually
> > > goes there because I'm not using the Epson driver. Perhaps the light
> > > black position in the print had incapable of laying down as much ink
> > > as the black position, but I've never heard mention of this.
> > > I've already tried asking MIS about this, both on their forums and to
> > > their tech support, but received no response.
> > > Any help would appreciated.
> > > -Jon
> > > Please visit the Group Homepage to check the Files, and other
> resources as
> > > they are often being updated.
> > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > > If you wish to receive no emails or just a daily digest, or you
> wish to
> > > unsubscribe, please edit your Membership preferences by visiting
> this same
> > > page.
> > > Please follow these basic guidelines:
> > > - As threads develop, trim off excess portions of earlier messages
> to keep
> > > them short.
> > > - Good manners are required at all time. No personal attacks or
> flames.
> > > Hostile, aggressive or argumentative users may be removed from the
> > > membership without notice.
> > > - Keep your posts and threads related to the group topic of
> digital B&W
> > > printing. Users who persistently make off-topic posts may be
> removed from
> > > the membership.
> > > - By posting on this forum you agree to abide by the group rules and
> > > guidelines, and to abide by the actions and decisions of the group
> Owner
> > > and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> > > section:
> > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT
> > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO
> > > YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> > > EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> > > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> > > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE
> BEEN
> > > ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i)
> THE USE
> > > OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> > > UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR
> DATA; (iii)
> > > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> > > YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> > > PRINT YAHOO GROUP.
> > > Yahoo! Groups Links
> page.
> them short.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> section:
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> PRINT YAHOO GROUP.
