Re: [Digital BW] Digest Number 3404
2005-09-09 by dwardphd@aol.com
In a message dated 9/9/2005 5:10:02 A.M. Eastern Daylight Time, DigitalBlackandWhiteThePrint@yahoogroups.com writes: Message: 3 Date: Thu, 08 Sep 2005 21:10:03 -0000
From: "Mark Hahn" <markhahn2000@...> Subject: Re: FAQ? HP 8750 vs. Epson R2400 for B&W ok, I was the one who mentioned HP Premium Plus Glossy puckering up and contacting the glass when hinged behind an 8-ply museum mat. If a traditional archival hinged mat sandwich is the wrong way to mount this paper, what are you saying is the right way to do it? mark Heavy fine art papers can be hinged in this way, but I've found that 'photo paper' weight papers like the HP (or Epson, Ilford, etc.) need to be mounted to a substrate such as foam core or they will warp and pucker. If you don't have access to a heat mounting press, try 3-M Postionable Adhesive. It comes in rolls of various widths and is easy and effective. David V. Ward David V. Ward Fine Art Photography www.dvward.com [Non-text portions of this message have been removed]
