Difference Between UT and UT7 Ink for a 2200
2005-09-23 by Tom Husband
What's the difference between the UT and UT7 inks for a 2200?  Here's
what I see.  UT7 uses 7 inks and UT uses just 6 with a choice between
Eboni and Photo Black making the 7th ink?  UT7 uses black, 3 grays and
2 cool toners where UT has only one cool toner.  UT can be used with
QTR but not the Roark curves where UT7 can be used with both.  Is that
right?  Are the characteristics of the inks different?
Tom
RE: [Digital BW] Difference Between UT and UT7 Ink for a 2200
2005-09-23 by Paul Roark
Tom,
The UT for the 2200 was an inkset MIS made for Bowhaus and the IJC rip.  It
will not run well with the Epson driver.
The UT7 inkset is for the Epson driver or a rip.  It does not usually have a
PK, using the 2 dark grays to generate the black.
>  Here's
I think that is an accurate summary.  The basic ink characteristics should
be the same.  (If there is old stock of one of them, it could have the old
base as opposed to the new base.)
Thanks Paul,
How about UT2 and UT7 ink?  With the exception that
UT2 is for the 1280 any other differences?
Tom
--- Paul Roark <paul.roark@...> wrote:
Tom,
for a 2200?
and the IJC rip.  It
>  Here's
a choice between
black, 3 grays and
can be used with
with both.  Is that
different?
Tom,
The UT2 and UT7 inksets are close but not identical siblings.
The differences were largely dictated by the differences between a driver
designed for dye inks (1280) and one designed for pigment inks (2200).
In particular, the cyan and magenta channels are switched.  The cool ink is
in the UT-2 (1280) C & LC positions, but in the UT7 (2200 and other UC
printers) M & LM positions.  This made for more even printing and a toner
that is lower in gamut than the Ut2 toner.  How low I can get the gamut of
the toners affects the smoothness of the prints by reducing the color
contrast between the dots.  (The next generation will have even lower gamut
-- and no sepia in the default arrangement.)
> Tom,
> for a 2200?
> and the IJC rip.  It
> >  Here's
> a choice between
> black, 3 grays and
> can be used with
> with both.  Is that
> different?
> Paul
> www.PaulRoark.com
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
