ICC/ABW shadow compression figures . . .
2005-10-25 by wwodets
In followup to the discussion on QTR Create ICC and and the shadow
compression issue I looked at the ABW driver settings.  A selection
of "Light" (instead of the Neutral-Darker default setting) in ABW
produced the following numbers.  These are for blacks at 90 to 100.
The ABW Light is shown first, the default ABW Neutral-Darker second
in parentheses:
HPR:
90  23.93 (18.42)
92  21.68 (17.69)
94  19.90 (17.21)
96  17.99 (16.94)
98  17.19 (16.69)
100 16.91 (16.80)
VFA:
90  24.67 (19.38)
92  22.72 (17.60)
94  20.68 (16.41)
96  18.63 (15.48)
98  16.66 (14.47)
100 14.19 (13.83)
Note that on both papers there is a slight reduction in Dmax with the
light setting.  Both also showed similarly smooth curves above 90,
but the Light setting curves have a slight, smooth sag through the
midrange (darker).
I also tried the "Normal" driver setting (between Neutral-Darker and
Light) which does about what you'd think it would.  The figures are
between the other two.  It was just enough to undo the HPR reversal
(96=17.77, 98=17.15, 100=17.05)
What do others think about the ABW driver settings as a basis for
Create ICC profiling?  My impression is that the Light setting is a
better starting point (linearization) for profiling.
Walt
Re: [Digital BW] ICC/ABW shadow compression figures . . .
2005-10-25 by Tom Baker
This is a bit disconcerting.  It seems that the Dmax should remain the same for any given paper.  If it doesn't, how can optimal results be achieved with all settings?  And, there is a linerization problem in at least on case.  SInce it's not great, maybe it could be compensated for by a good profile.  But, I wonder if the variable dmax problem can be fixed.
Tom Baker
in parentheses:
HPR:
90  23.93 (18.42)
92  21.68 (17.69)
94  19.90 (17.21)
96  17.99 (16.94)
98  17.19 (16.69)
100 16.91 (16.80)
VFA:
90  24.67 (19.38)
92  22.72 (17.60)
94  20.68 (16.41)
96  18.63 (15.48)
98  16.66 (14.47)
100 14.19 (13.83)
midrange (darker).
Walt
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
YAHOO! GROUPS LINKS
    Visit your group "DigitalBlackandWhiteThePrint" on the web.
Tom Baker
in parentheses:
HPR:
90  23.93 (18.42)
92  21.68 (17.69)
94  19.90 (17.21)
96  17.99 (16.94)
98  17.19 (16.69)
100 16.91 (16.80)
VFA:
90  24.67 (19.38)
92  22.72 (17.60)
94  20.68 (16.41)
96  18.63 (15.48)
98  16.66 (14.47)
100 14.19 (13.83)
midrange (darker).
Walt
YAHOO! GROUPS LINKS
Tom Baker
in parentheses:
HPR:
90  23.93 (18.42)
92  21.68 (17.69)
94  19.90 (17.21)
96  17.99 (16.94)
98  17.19 (16.69)
100 16.91 (16.80)
VFA:
90  24.67 (19.38)
92  22.72 (17.60)
94  20.68 (16.41)
96  18.63 (15.48)
98  16.66 (14.47)
100 14.19 (13.83)
midrange (darker).
Walt
YAHOO! GROUPS LINKS
