K7 in 6 channel printers
2005-11-03 by john dean
Is anyone using Neutral Piezzotone in a 6 channel printer with QTR? If
so, how is it working for you?
John
Re: K7 in 6 channel printers
2005-11-03 by Greg
> John
Does this mean you got your 7000 running? Or are you considering
switching your 10K over?
2005-11-03 by Tyler Boley
John, I really think you're going to be the bleeding edge on this setup.
Tyler
> John
Hi Greg,
Actually both. It looks like I have another 7000 to try it out with,
and if I like it then I want to do it with the 10K since I still have
about 50% of the life in that machine. And, it's fast.
By Jan I'm going to be finally set up to do larger Piezzotone, one way
or another. I just haven't decided what set to use yet. I don't have a
thing against the selenium tone set. I really like the quads, they are
 beautiful but the new set seems to be totally clog free and quite
smooth. I'm still listening, and I will do it, I will, I will....
Right now I'm trying to buy a house. Not cheap in this city.
John
--- In DigitalBlackandWhiteThePrint@...m, "Greg"
> > John
2005-11-03 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
setup.
> Tyler
Shouldn't be too much of an issue when using one of the RIPs (QTR or
StudioPrint), just need to leave out the darkest gray, and stretch the
full black a bit more, maybe a longer overlap between black and the
other shades. It's the lightest inks that will make the biggest
difference in the quality.
And normally those early printers were pretty bullit proof (notice the
word normally). As long as parts are available, there doesn't seem to
be a compelling reason to get rid of them (just repurpose them). The
9000/9500 is a tank, but it is a bit slow (speed kills?).
That is what Mr. Cone says.
What I am thinking is that these earlier printers should be almost
clogg free with that set, making them ideal, if the tonality is right.
Which is THE most important if, as Tyler suggests.
john
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg"
> setup.
> > Tyler
2005-11-03 by Roy Harrington
John,
I've set my printer up for this, but due to some head problems
its not quite operational.  But from what the experiments it works quite
nicely.  The original idea for K6 was to leave out the middle gray but
my experimenting with that convinced me the jump was too large from
K3 to K5.  Dots were much more visible in this range.  I decided to leave out
the lightest ink since the next-to-lightest is still very light.  There is one
profile in the 2.3.1 download for this setup with Y being K4 rather than K7.
I'd recommend that setup but I haven't seen the leave-out-the-K2 scheme.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg" <dfaprinting@y...>
> setup.
> > Tyler
There you go Roy. Thanks for that insight. Now that makes total sense
to me, and avoids messing with near black values, although it could
work both ways I suspect. I'll ask you more in a couple of weeks when
I actually get down to doing something serious.
Thanks again,
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
<roy@h...> wrote:
> John,
leave out
There is one
than K7.
> Roy
<dfaprinting@y...>
> > setup.
> > > Tyler
2005-11-04 by Greg
Leaving out the lightest ink is probably the easiest method, as long
as you don't start to get visible dots in the highlights. Chances are
that you won't see any dots up there anyway.
And I wouldn't go so far as to say that the older machine would be
clog free. Part of the reason that the newer printers have fewer
problems is the cleaning routine that they use when you turn them on.
If you set the default cleaning on an old 7 or 9 series machine to a
heavier cleaning, many of the clogging problems go away. But I would
still recommend using it as often as possible.
2005-11-04 by john dean
True, but the nozzles are not quite as fine as the newer machines, but
primarily I was refering to the slippery and clog resistant nature of
the K7 inkset in those machines vs the previous set. But, yea, you
don't want anything to sit in there too long I wouldn't imagine. But I
work everyday.
John
2005-11-04 by Tyler Boley
Right, that kinda has me leaning toward leaving out the K2 for that
printer...
Besides, even the K3 is probably darker than the dark gray in the quad
sets, so the K3 to K transition should be easy enough. Sometimes I
think the quad sets are all too dark anyway, the dark gray is
generally jammed right up against K.
Conversely, If Roy sees no dots with his K6 without the lightest,
there's a reliable answer. The above is all theory.
The only K6 prints I've seen were custom mixed/diluted.
Also, the printers I know with 7000/9000s using the non-K7 piezotone
sets have no ink problems. For a 7000 I wouldn't make ink delivery or
performance too much of a deciding factor. Newer model? Then I'd
factor it in to my decision, but not too highly.
Tyler
