Possible to cut Epson paper rolls?
2005-11-08 by roleiman
Friends I print on an Epson R2400. The maximum stock width is 13". For
my best, I print on Epson UltraSmooth 13x19 which rings in at $4 per
sheet. Unfortunately, the narrowest roll stock is 17". There is a 44"
roll that, cut in  3 13" segments would give me 150 feet, at around $1
less per foot. And it would be more econmical because there would be
no waste in the length as there is with the pre-cut stock. Any
suggestions as to how to get this cut professionally. I have a chain
saw. I am looking for something a bit more accurate. Thanks
Re: Possible to cut Epson paper rolls?
2005-11-08 by richard_h95050
Exim Vaios is an excellent Epson Pro dealer that also cuts custom sized
rolls and sheets. They have many different sizes and paper types in
stock including Epson Ultrasmooth in 13" widths.
I just received a sample package from them and found the products to be
quite good. They are very customer service oriented, so I'd suggest
giving them a call.
Here's a link to their Website (click " Paper & Media/Custom Cut"):
http://www.eximvaios.com/catalog/default.php
Hope this resource is helpful to all...
Cheers!
Richard
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "roleiman"
For
$1
Richrd, Many thanks for the response and resource.
David
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "richard_h95050"
sized
in
to be
suggest
> giving them a call.
> Cheers!
> Richard
13".
> For
per
a 44"
around
> $1
would be
chain
2005-11-08 by Frank Kolwicz
I did this to try some highly recommended Epson papers and it may not be worth the savings, depending. A large "T" square (I use a sheetrock cutter's for the size and price), a sharp knife and a cutting pad (I use a piece of mat board but cardboard will probably work) are all you need. But before you do that I suggest that you try to flatten the roll first and that can be tricky because you have to roll it backwards while handling the printable surface and it's pretty easy to make those little half-moon creases, so it requires a lot of care. I tried to re-roll the whole roll on the Epson core, but that wasn't tight enough to take out all the curvature. Finally, I made a special rolling core with a piece of 1&1/4 inch plastic pipe to which I taped a few sheets of plain wrapping paper as protection for the Epson paper - that worked for each cut sheet before use, but by that time I had put so much effort into that I decided it wasn't worth it and just switched to back cut sheets (Kayenta, as the price and quality are right for me).
Frank
_____________________________________________________
Subject: Possible to cut Epson paper rolls?
2005-11-09 by roleiman
Frank, that sounds like a lot of work. I know how delicate these
fine papers are. I am sure that I'd end up getting my greasy paws
all over it, and end up starting my wood stove with it. I just want
a roll cut to size. Thanks for yours.
David
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Frank Kolwicz
> Frank
>  From: "roleiman" <simsedg@a...>
For
per
44"
around $1
be
chain
Richard, Exim is just the ticket. A 50' roll of 13" Ultra Smooth is
$81 vs 40' of sheet stock for over $100.
I have never used the roller on my R2400 (just got it). Do I need
some sort of paper cutter?
David
--- In
sized
in
to be
suggest
> giving them a call.
> Cheers!
> Richard
13".
> For
per
a 44"
around
> $1
would be
chain
2005-11-09 by richard_h95050
Hi David,
Yes, Exim Vaios is a really good supplier! They have both custom-cut
roles of all kinds of fine-art papers as well as roll paper cut into
sheets that you can't get anywhere else.
It's not recommended that you use the printer's automatic cutter on
the heavier papers, even on the wide-format machines. Whether you
should buy a paper cutter or use a blade and a T-square probably
depends on your own taste and how much cutting you'll be doing.
My own thinking is that if you'll be doing a lot of printing then a
paper cutter sort of "goes with the territory" along with trimming
things to taste when printing and mounting. I think it's an important
investment, but YMMV ;>)
Glad this info was helpful...
Richard
> Regards,
> David
> --- In
> DigitalBlackandWhiteThePrint@...m, "richard_h95050"
> sized
> in
> to be
> suggest
> > giving them a call.
Cut"):
> > Cheers!
> > Richard
<snip>
Richard, is printing with a paper roll a hassle? I had posted a
similar querie on another forum, and a responder suggested that
dealing with paper curl is an issue. I like the fact that you only
use as much paper as you need. I shoot 6x6cm and generally crop
little in order to keep the square look. With a 12"x12" image, I am
throwing away a third of a 13x19 piece of paper. Perhaps they would
cut me 13x13 sheets. Thanks again.
David
--- In
> Hi David,
cut
into
on
a
important
> Cheers,
> Richard
is
need
> > Regards,
> > David
> > --- In
custom
> > sized
types
> > in
products
> > to be
> > suggest
> > > giving them a call.
> Cut"):
> > > Cheers!
> > > Richard
> <snip>
Hi David,
Whatever hassle may be involved with printing from roll paper is
something I've become accustomed to and integrated into my workflow
because I use Epson wide-format machines -- it just goes with the
territory there and printing from rolls is very typical.
Exim Vaios will cut sheets of most anything, but I believe they have
some quantity requirements to make it cost effective for both buyer
and seller. You might want to speak with them about that directly,
and if you settle in on a favorite paper or two, it may be well worth
your while to purchase a quantity cut to your custom dimensions.
Let us know how that works out...
Cheers!
Richard
> David
> --- In
> > Hi David,
> cut
> into
> on
> a
trimming
> important
> > Cheers,
> > Richard
<snip>
