Printing with MIS Ultratone FSN in an Epson 2000P
2005-11-09 by Andrew Brilliant
Has anyone used this combination using MIS cartridges pre filled.
And following Paul Roarks  workflow.
I was printing early on with an 1160 and the cone inks and later mis
using the piezography  software and had success.  I ran through two
1160's that  need to be refurbished or chucked.
I was busy working on commercial assignments and was not doing any
printing  but now I need to get back to B&W so I am  hoping to get
the 2000p working as a black and white printer.
I followed the  Roark workflow on  OS10 but the epson driver and
photoshop CS2 have slightly different setting options and so far no
luck in getting any kinds of matches to screen.  Plus the driver is
adding extra lines outside of the image.     Strange, I thought maybe
it was mechanical.
When I switched to Photoshop 7 and OS 9   I did have better
results    but I don't want to go back there unless it is  absolutely
the only way to go.    Also I am running into some clogs with these
cartridges and the the 2000P never ever clogged  with epson ink and
this is making me very nervous about this choice.
Is anyone else out there working with the 2000p and having
success???    If you are,  can you refill these cartridges easily.
I have already contacted Paul and he was helpful but I got the
impression that he has not used this particular combination of inks
and systems in the 2000p
Andrew Brilliant
www.brilliantpictures.com
