Papers and packaging for 40x50 prints
2005-11-08 by mccarvill
I'm planning to order some 40x50 prints on an Epson 9600 in the near
future and would be interested in recommendations and advice from those
with experience printing at this size.
One print shop I contacted has recommended against my first choice for
paper (Epson premium luster), saying it's relatively thin, so large
prints are more prone to damage, creases and scuffs. He recommended
going with a matte paper, like Epson enhanced matte or Ultrasmooth, or
a watercolor paper. I'm not a fan of textured papers or those with
flaking issues. What are your favorite paper in this format, especially
among the luster or semi-glossy papers?
Also, I have an option of getting the prints packaged in 3" tubes or
flat between foamcore. Any recommendations here?
Thanks
Re: [Digital BW] Papers and packaging for 40x50 prints
2005-11-08 by hogarth@snappydsl.net
> Thanks
Since you are using inches, I assume you are in the USA. You should note
that the largest "normal" size for matte boards in the USA is 40x60
inches. This begs the question of how you are going to display your
prints. My largest size for prints on paper is around 30x40 inches
because of the 40x60 inch limitation on matte board. Anything larger I
put on canvas and frame in a floater frame without glass. But... there
are many paths to the waterfall.
Shipping a print of any size in a 3" tube is IMHO a bad idea. Why can't
your vendor use a 6" tube? A 3" tube will most likely put a marked curl
in your print. Most art papers would be difficult to roll tight enough
to get into the tube that small, and the risk of damage in getting a
large print into a tiny tube is something to consider.
These are just some things that your vendor should have told you be
evidently didn't.
Bruce Watson
2005-11-08 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, hogarth@s... wrote:
Objects that large may have to be shipped by truck freight if you ship
it flat.
2005-11-09 by mccarvill
Good points, Bruce.
I intend to mat them, so I should probably stick to 30 x 40 too. Just
curious – what's your finished size on a 30 x 40 print, including the
mat?
And I'll either get 6" tubes or have them packaged between sheets of
foam core.
Mark
wrote:
near
those
choice for
large
recommended
Ultrasmooth, or
especially
or
> > Thanks
note
larger I
there
can't
curl
enough
a
> evidently didn't.
> Bruce Watson
2005-11-09 by hogarth@snappydsl.net
mccarvill wrote:
> Good points, Bruce.
> curious \ufffd what's your finished size on a 30 x 40 print, including the
> mat?
> foam core.
> Mark
I'm hardly what anyone would want to use as a guide! But since you asked...
My size in that range is 100 x 80 cm (39.4 x 31.5 in). My frame size
then is 48 x 39.5 in. Not a lot of waste left from a 40 x 60 in. sheet
of matte board ;-)
You can do the math and see how wide the window boarder is.
Interestingly, I've found that as a print gets larger, the matting
boarder tends to get smaller. Unfortunately, the window matte also seems
to want to get thicker too. I'm using 8-ply matte boards at that size.
That little extra thickness helps control the large print and keeps it
from touching the glazing, but more importantly it just looks more
proportional to me.
That's what I do, more or less. It varies depending on the image of
course. But just because it works for me doesn't mean that anyone else
has to do it that way. Clearly, YMMV.
Bruce Watson
