Channel Mixer and Lab L Channel
2005-11-10 by Steve Kale
I am puzzled by something I stumbled across yesterday. I was working up an image converted to B&W with Channel Mixer (60% Green, 40% Blue). I wanted to sharpen the image and tried a variation of the Smart Sharpen/Reduce Noise Sharpen action I use - specifically I copied the image, converted it to Lab Colour Mode (flattening in the process) and only sharpened the L channel. I made a mistake while doing this and brought just the L channel of the copy over to the original as a layer. This revealed something I found surprising: the Lab Colour copy ( a flattened greyscale image) had luminance information in the a and b channels. That is the luminance of the L channel alone was different from the luminance when all three (L, a and b) are displayed. This would seem to fly in the face of what I thought the a and b channels represented. I did another quick test. I took the RGB original with the Channel Mixer layer and flattened it, leaving a greyscale image in RGB. Converted it to Lab. If I uncheck either one of the a and b channels the image stays looking the same. But if I uncheck both the a and b channels (leaving just the Lightness channel displayed) the luminance of the image changes significantly. I must be missing something basic but I don't quite get it.... Ideas? Steve PS: I am using PS CS2. (My RGB space is ProPhoto RGB.)
