I have UT7-PKN plus UT7 plus UT-FSN-Y in the Y position installed on
R200, same setup as John Moody discussed here some time ago. I used
this set to prepare curves for QTR. After reading Paul's reply I
tried to print through Epson driver using color controls, and result
was pretty good, I would say not worse than my prints through QTR. I
didn't play with controls, but it is clear that this inkset will be
very nice in R200/R220 using Paul's workflow.
On that printer QTR exposes banding on the top 2 inches of page,
driver prints fine.
Sergei
<paul.roark@v...> wrote:
> > Does anyone have any experience using MIS UT or UT2 inks in an
Epson
> > R200? I have been using UT-FSN in an Epson C86 with excellent
results.
> > I have created transfer curves for the same ink and paper
combinations
> > on an R200, but the prints produced are cooler than images
printed on
> > the C86. A variable tone ink set may solve this problem. The C86
> > prints are really very nice. Too bad the printer isn't better
made ...
> I currently have UT7 inks loaded in my R220, and they worked very
well. I
> omitted the sepia (and, of course, there is not LK), using a
second light
> carbon (UT7-LC) in the Y position. With no curves or adjustments
at all,
> the setup prints just slightly warm on EEM. With slider controls
to adjust
> the hue, Create ICC was able to straighten out the ramps, giving
very good
> images from tones/hues equal to about FS on the warm side (half
way to
> carbon) and slightly cool on that end. The hues were very even on
the ramps
> using this approach. Curves, of course, can cover the entire
range from
> carbon to cold with this setup, but they're much more work to make.
> I didn't use UT2 because I thought the setup would be too cold.
The UT2
> toner is stronger than the UT7 toner. I used the UT7 ink
placement for the
> toner and carbon inks in the magenta and cyan positions,
respectively.
> I have not put anything on my web page about this. I'm not sure
MIS is
> interested in supporting it. You'd have to buy the inks in bulk
(4 oz.)
> and load your own for this approach -- which is the most efficient
approach
> anyway.
> Good luck.
> Paul
> www.PaulRoark.com
