Bill Atkinson's Target Reference Files
2005-12-09 by Steve Kale
Sorry for posting this here but I'd prefer the conversation to be a little further away from public colour forums for reasons which will become apparent. Respond off-list if appropriate. Has anyone tried running Bill's reference files and targets through EyeOne Match? He uses his 4096 patch target for his new 9800 profiles. Match can't read these because it seems to be limited to 119 rows of data. It can measure wider (more columns) but the ruler isn't wide enough. (Bill's targets are 32 columns wide - the max for the i1 ruler - while the default Match targets 27.) So if you load Bill's 4096 reference file in Match you can't measure the last 9 rows. Obviously MeasureTool can read the 4096 patch target but the data still needs to be processed into an ICC profile by a profiling application. That's fine if you have the very expensive PM5 but I'm wondering if Match can process a higher observation data set than it can read. For example, if one read the data with MeasureTool, saved it and then loaded the measured data into Match would the profile use all the data points? If anyone has dabbled with this I'd be very interested.
