7500 spitting ink
2005-12-16 by Paul Roark
My 7500 seems to be spitting ink on the left edge (as I face the printer) of usually large prints with increasing frequency. Is there a good way to stop this? Paul www.PaulRoark.com <http://www.paulroark.com/> [Non-text portions of this message have been removed]
2005-12-16 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote: > > My 7500 seems to be spitting ink on the left edge (as I face the printer) of > usually large prints with increasing frequency. Is there a good way to stop > this? > > > Are these "large" drops of inks? It might be that you have a partially clogged nozzle. As the inks spray a small portion is held back and starts to form a drop, when the drop is big enough... SPLAT! Can also be caused be hair or paper fibers stuck to the head. A thorough cleaning of the nozzle side of the head, and the sides of the head might be in order. Replacing the head cleaner (wiper) might help too. Are you seeing an increase in the number of clogs? If you are seeing an increase, might be time for a new capping station and ink pump. Tearing the covers off might be the hardest part of all this work. Running cleaning fluid through the lines and heads might be a good idea too, do that before tearing the machine apart as it will help to prevent the ink inside the heads from drying while you are messing around cleaning the other parts. The other thing that could be causing it (less likely) is the pressure in the ink lines. Too much pressure and you start to get drops forming on the head. As those drops accumulate more ink from the spraying nozzles, the drop gets bigger, until SPLAT! Since you refill carts, that is much less likely than goop on the heads. You do have a service manual for that printer right? Last time I checked, the entire maintenance kit (head cleaner, capping station, ink pump, waste ink pads, flush box left and right) was only $125
2005-12-16 by john dean
Paul, you are going to get the best help for this on the yahoo large format Epson group.It seems the best tech guys hang out over there. However, if I were you I would check to see if one of your dampers is loose. The dampers are the little clear filters that attach to each line of ink and fit directly into the two print heads. You have one print head for each of the three sides of ink, 3 dampers for the the lights and three for the darks. Do you have a 7000 series manual? If not I might be able to help you there to lean how to remove the head cover and check the heads. John --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote: > > My 7500 seems to be spitting ink on the left edge (as I face the printer) of > usually large prints with increasing frequency. Is there a good way to stop
> this? > > > > Paul > > www.PaulRoark.com <http://www.paulroark.com/> > > > > > > [Non-text portions of this message have been removed] >
2005-12-16 by Ernst Dinkla
> this?
> Paul
Usually the wiper blade at the capping station that isn't
effective. Clean it + the capping station, both with Windex
and dry the blade with a small cloth. Check the rubber edge,
look for a sharp edge and abrasion marks. Replace it if it is
not sharp or has ragged edges. ( I once got a "refurbished"
9000 that had the wiper blade reverse mounted so the felt side
had to wipe the head, didn't work :-) Check the rubber edges
around the sponges in the capping station. Remove any paper
lint. Check whether that wiper blade goes still up down, the
same for the capping station. Windex will clean the mechanism
as well. Vacuum clean the surrounding area so no new paper
lint can get in. Do a capping station alignment.
Better clean the head as well. Found a new method that's
easier and better than the wet cloth etc. At the left side of
the 9000/9500 is a kind of rectangular spitting hole. Cut a
sponge so it can be inserted in that hole but sticks out
approx 1/4 inch. That can soak more windex/warm water and is
flexible enough not to harm the nozzle surfaces. Size has to
be about 65 mm long, 14 mm wide, 30 mm high. The head can be
moved over the sponge and the dirt will be soaked and get in
the sponge. There may be some water + ink on the printer but
it can be cleaned easily and it is outside the paper transport
area. The head can be parked again and a cleaning done to wipe
the surface again. Remove the sponge and clean it for the next
time. Making a kind of toothbrush surface on the sponge and
also add an extra rim at the top to take away the dirt that
accumulates around the edge at the top of the head (usually
offsetting dirt to the grey paper pressure rolls) would make
an even better washer sponge. So far I take that dirt off
with a soaked shoe lace.
Ernst Dinkla
www.pigment-print.com
( unvollendet )2005-12-16 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <E.Dinkla@c...> wrote: > So far I take that dirt off > with a soaked shoe lace. > I'll have to try that, it's about time to do that type of work on my 9500 again.
2005-12-16 by sinar001
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg" <dfaprinting@y...> wrote: > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla > <E.Dinkla@c...> wrote: > > So far I take that dirt off > > with a soaked shoe lace. > > > > I'll have to try that, it's about time to do that type of work on my > 9500 again. > I find that cleaning the wiper blade and capping station, is something that should be done after every print run, or whenever you have trouble getting a good nozzle check. Pigmented inks cause many build=up problems, which didn't happen with dye inks. John Nollendorfs
2005-12-16 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sinar001" <jnolly@a...> wrote: > > I find that cleaning the wiper blade and capping station, is something that should be done > after every print run, or whenever you have trouble getting a good nozzle check. > > Pigmented inks cause many build=up problems, which didn't happen with dye inks. > > John Nollendorfs > The third party pigment inks seem to cause more build up than the Epson inks, or at least the "thicker" pigments that I've been using. Sometimes I find a buildup on the flush box - right which is just ink stuck to itself to form a large glob, same happens to the cleaner, but I normally keep that wiped off more often.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg" <dfaprinting@y...> wrote: SNIP > The third party pigment inks seem to cause more build up than the Epson > inks, or at least the "thicker" pigments that I've been using. > Sometimes I find a buildup on the flush box - right which is just ink > stuck to itself to form a large glob, same happens to the cleaner, but > I normally keep that wiped off more often. > The large vinyl tube (from the Flush box) on the older 9000/9500's is prone to "backing up" because it rests flat on the waste ink pads. I generally cut it off on a diagonal to prevent such back ups! John Nollendorfs
Success -- thanks to you guys. The 4 foot print for the museum came out without a spot after a thorough cleaning of the printer, especially the wiper blade that had dog hair on it. Paul www.PaulRoark.com
2005-12-16 by Mark Savoia
Hair of the dog is suppose to be good for you the next day. On Dec 16, 2005, at 2:21 PM, Paul Roark wrote: > blade that had dog hair on it.
2005-12-16 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sinar001" <jnolly@a...> wrote: > The large vinyl tube (from the Flush box) on the older 9000/9500's is prone to "backing > up" because it rests flat on the waste ink pads. I generally cut it off on a diagonal to > prevent such back ups! > All the new ones in the kit are cut at an angle. The build up I was describing is happening in the rigid plastic part, it's catching on the places where the "anti foam" pad used to be. They removed the pad, but left the projections that held it. I might need to adjust tyhe position a little too, but as long as the ink goes into the flush box and not all over the printer, I don't care so much.
