spongeless carts refill procedure
2005-12-15 by aitor67
I have received the cartride from Mis, But I don�t have idea where to
start. The instructions are not clear for me , my english is not as
good as I wish. I don`t know what is the white looking rubber plug
that must be remove. I f anyone could explain me it easy will be
apreciate.
Anyway if there is anyone that speak spanish wold be great
best regards
Re: [Digital BW] spongeless carts refill procedure
2005-12-15 by aitor Peña Inclán
Hi again,
If anyone hace pics of the refill procedure would be a great help too. I'm
really lost. ( I think I have broken the cart :-(
aitor67  el 15/12/05 20:02 escribió
> I have received the cartride from Mis, But I don´t have idea where to
> apreciate.
> best regards
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See ³Group Topic, Rules and Guidelines² in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ³OWNER² AND
> ³MODERATORS² OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  ³OWNER² AND ³MODERATORS² OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
Aitor Peña Inclán
Dr. Díaz Emparanza 39 3º
Tf: 944447194
Mov: 607444460
48002 Bilbao
SPAIN
http://www.aitorpinclan.com
RE: [Digital BW] spongeless carts refill procedure
2005-12-15 by Paul Roark
Have you taken a look at this: http://www.inksupply.com/c86_slc_refill.cfm
MIS has a number of refill instructions listed here:
http://www.inksupply.com/direct.cfm
See if any of these help.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of aitor
> Pe ñ a Incl á n
> Sent: Thursday, December 15, 2005 11:58 AM
> Subject: Re: [Digital BW] spongeless carts refill procedure
> Hi again,
> > apreciate.
> > best regards
> as
> same
> > page.
> keep
> > them short.
> membership
> > without notice.
> from the
> > membership.
> and
> section:
> YOU
> EXEMPLARY
> GOODWILL,
> ³MODERATORS² OF
> OF SUCH
> DIGITAL BW,
> THE
> THE
> > Yahoo! Groups Links
> Aitor Peña Inclán
> Tf: 944447194
> Mov: 607444460
> 48002 Bilbao
> SPAIN
> page.
> them short.
> membership without notice.
> the membership.
> and Moderators. See “Group Topic, Rules and Guidelines” in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
> “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
Thaks paul,
Is this what I don't understand
2- Carefully remove the white looking rubber plug from the top of the cart
(opposite of chip end). Try not to damage it because you will want to use it
again. A pin or Xacto knife can be used if you are careful. After the plugs
are removed, if there is any clear plastic extending over the hole the plug
came out of, remove it with your Xacto knife. Just the part extending over
the hole, not any more of it.
> Paul
> www.PaulRoark.com
There is a small rubber stopper or "cork" -- it is usually clear -- that is
often flush with the top of the cart.  The stopper needs to be removed to
fill the cart from the top.  I use a small jeweler's screwdriver, like the
ones that are used to tighten eyeglasses.  I've been able to slip it down
between the edge of the stopper and the hard plastic cart hole.  Once it is
down below the stopper level, I can pry out the stopper without damaging it.
Be sure once the cart is filled the first time that you "prime" the cart by
holding a finger over the small air inlet and while the stopper is still out
of the top.  The idea is to pull some ink down into the cart outlet.
Otherwise there can be a persistent air bubble there.
Good luck.
> Pe ñ a Incl á n
> Sent: Thursday, December 15, 2005 12:15 PM
> Thaks paul,
> it
> plugs
> plug
> > Paul
> > www.PaulRoark.com
> page.
> them short.
> the membership.
> section:
> PRINT YAHOO GROUP.
Thanks Paul,
The printer is a 1290 . I can't see this cork in the spongeless cartdrige
Mis send me.
http://www.inksupply.com/spongless_carts.cfm
> Good luck.
> Paul
> www.PaulRoark.com
>> -----Original Message-----
>> Pe ñ a Incl á n
>> Thaks paul,
>> it
>> plugs
>> plug
>>> Paul
>>> www.PaulRoark.com
>> page.
>> them short.
>> the membership.
>> and Moderators. See ³Group Topic, Rules and Guidelines² in the Files
>> section:
>> ³OWNER² AND ³MODERATORS² OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
>> PRINT YAHOO GROUP.
>> Yahoo! Groups Links
> page.
> them short.
> without notice.
> membership.
2005-12-15 by kenstrain2000
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, aitor Peña Inclán
<aitor.pinclan@t...> wrote:
> Thanks Paul,
cartdrige
> Mis send me.
Sometimes the 5 "corks" come in a little bag with the cartridge. Then
there are 5 empty holes in the cartridge.  You fill the ink (not quite
to the top - leave about 4mm), "prime",  and put the corks in as tight
as possible.  If there is no cork there must be a hole.  Sometimes it
is hard to find the little bag of plugs in the packing material
(othertimes they are in the box with the cartridge).
Ken
2005-12-15 by John Vitollo
The "corks" or stoppers should be in a small bag that's easy to miss in the box...
I forgot...but i think the bag was stapled to instructions?
LoL,
Thanks Kenstrain,
I am thinking I am crazy. I have been some hours watching the carts... Where
are those corks ???????
Yes, It has been in  a little bag so I only see holes.
>> Thanks Paul,
> cartdrige
>> Mis send me.
Some questions
2005-12-16 by aitor Peña Inclán
First excuse me if this questions has been answered in this list. There is a
lot of heplful information here and sometimes I can't read everything
1- Print wirh preview dialog in CS2
It have changed and now I cant't see  "same as source" wich must I select
now. ( print with paul cuerves and UT2 in a 1290 )
2- H. photorag satin
I'm interested in any satin paper. What's your opinion about this paper and
wich curve is the appropiate fotr it.
TIA
Aitor
Re: Some questions
2005-12-16 by John Vitollo
"Same as source" in CS2 is "No Color Mangement"
