Re: [Digital BW] 4800 Colorbase (color issue)
2006-01-16 by CDTobie@aol.com
In a message dated 1/16/06 4:29:27 AM, odesmais@... writes: > > Oppositely on Archival Matte with the proper driver settings the > results are below expectations not to say puzzling. With CB not > activated and a custom profile with no clb, the print is pretty good. > With CB clb file activated and a custom profile made with clb > activated the result is poor : on a portrait I often use for profile > assessment, the skin is reddish and bluish. > Just as a general issue: you need to run ColorBase on your printer, and have the CB calibration active, before building a custom profile in order for ColorBase to be valid with that profile. If you don't do it in this order then the profile would be expected to be less accurate with ColorBase than without it. This may or may not address your particular case... C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@... www.colorvision.com [Non-text portions of this message have been removed]
