For Tyler
2006-01-29 by Tom Baker
Tyler - Is it a big, long involved explanation, or trade secret about how you are doing the 'underprinting' you referred to in an post earlier today? Tom Baker [Non-text portions of this message have been removed]
2006-01-29 by Tyler Boley
Tom, I keep trying to reply and the list seems to be buggy tonight... Anyway, the short verion is that StudioPrint allows the user to assign more than one ink tank to the various protions of the quad (or whatever number of partitions you use) scale. So with any given ink setup, I assign an unused dark gray to K along with the actual K ink. Tyler --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tom Baker <tbaker1328@s...> wrote: > > Tyler - > > Is it a big, long involved explanation, or trade secret about how you are doing the 'underprinting' you referred to in an post earlier today?
> > Tom Baker > > > [Non-text portions of this message have been removed] >
Not to be a pest, but does it align the two dots perfectly? And, can you control which dot is laid down first?
Maybe I'm starting to see some of the 'good stuff' in SP.
THX
Tom Baker
Tyler
wrote:
> Tyler -
> Tom Baker
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
SPONSORED LINKS
Digital wedding photography Learn digital photography Digital photography college Digital photography Digital photography web site Digital photography course
YAHOO! GROUPS LINKS
Visit your group "DigitalBlackandWhiteThePrint" on the web.
[Non-text portions of this message have been removed]2006-01-29 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tom Baker <tbaker1328@s...> wrote: > > Not to be a pest, but does it align the two dots perfectly? Well that's complicated, and is an ongoing issue. In the current version it's called "distributed". For now let's say for my purposes using a double K it doesn't matter as at those densities you can't even really see dots. Certainly doubling up lighter inks, which I do for blends, it's possible that issue could be determined. I'd be more specific, but everything just changed with the new version and there is a lot of testing to do. Until I get to the bottom of it all I'm using old version 10 for quads, it does not do "distributed" and works fine for x600 printers, but there was lot's of bleed with 7000/9000 using double inks as they aparently put dots down differently. Distributed was supposed to fix this. > and And, can you control which dot is laid down first? No, and I have no way of knowing which is going down first. So the term "underprint" is not really correct. > Maybe I'm starting to see some of the 'good stuff' in SP. Things just got insanely more complicated. With each ink you can now control which of the 3 dot sizes per ink you want to use, and what percentage at each size. That's per ink, so for quads, per partition. A simple quad setup- 4 inks, density and percentage controlable with each, and within each of those 3 possible dot sizes to select any combination of, including each dot's percentage. Initial testing has yeilded a lot of failures and also a lot of promise. I've been able to get much smoother transitions, more levels of gray defined, etc.. but much more work still to do. Yikes... Tyler
2006-01-29 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tom Baker <tbaker1328@s...> wrote: > > Not to be a pest, but does it align the two dots perfectly? And, can you control which dot is laid down first? > > Maybe I'm starting to see some of the 'good stuff' in SP. > > THX > > Tom Baker > If you are printing unidirectional, then careful placement of the ink color will allow you to let black be put down first, last or in the middle. If you are using bidirectional, then it just gets laid down when the head passes the correct spot. I haven't seen a RIP that will make a special pass for just one color with these Epson printers. If there is that type of function, it might work well for placing GLOP over the finished printing.
