MIS inkjet clearing ink use
2006-02-01 by Allan Chen
Hi all,
	I just ordered up some of the nozzle clearing fluid from MIS.  I assume
that I should not have the carts in place while it's wicking up from the
parking pad, right?  Just checking.
allan
http://allan.kaiyen.com
http://photos.kaiyen.com
RE: [Digital BW] MIS inkjet clearing ink use
2006-02-02 by Paul Roark
Allan,
> I assume that I should not have the carts in place while it's
> wicking up from the parking pad, right?
I put windex or cleaning fluid on the pads with the carts still installed.
It's not going to bet very far into the system, as far as I can tell.  If
there is a bad clog, cleaning fluid in carts so that it gets into the
interior of the head will have a more dramatic effect.
Good luck.
Re: [Digital BW] MIS inkjet clearing ink use
2006-02-02 by Allan Chen
Thanks Paul.  Wish me luck.
allan
Paul Roark wrote:
> Allan,
> Good luck.
> Paul
> www.PaulRoark.com
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2006-02-03 by Allan Chen
Another question - should I leave the printer on?  I thought the nozzles
are closed when the printer is off?
allan
> allan
> Paul Roark wrote:
>>Allan,
>>Good luck.
>>Paul
>>www.PaulRoark.com
>>Yahoo! Groups Links
2006-02-03 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Allan Chen
nozzles
> allan
That last question will require a longer explanation that I can give
at the moment, and probably require so pictures that I'll have to
find. Short answer is that there is a tech.paper on the Epson
corporate site that explains how the printheads work. I'll look for
that link later this weekend.
The really short answer is that the nozzles never close.
When you put the Windex on the capping station, the printer should be
off. Then when yopu turn it back on, the printer will suck all the
(now) dissolved ink into the waste system, which will help to keep
that free from problems too.
2006-02-03 by Paul Roark
Like Greg suggested, I have the printer off and move the head over to the
left to soak the parking pad.  To do this, you have to move the top of the
gear on the far left inside the printer toward you to lower a peg that holds
the print head in its parking position at the right.  Then when the pads are
soaked and clean, move the head back to its position on the right, move the
gear away from you and turn the printer back on.
