OT: scanner question
2006-03-29 by michael3442
Sorry for the OT, but... I'm about to hook up a scanner (Epson 4870)
to make some large files from negs. Due to space limitations, I'd like
to put it in another room with an older computer. So the question is,
how much computer power does it take to make big scans? After scanning
I'd be sending the files through an ethernet network to their final
storage (& editing) space. Is the transferring where I would need the
computer power? Or, how about this: can I run the scanner through the
network, allowing me to use the more powerful computer in a different
location? Thanks.
Re: [Digital BW] OT: scanner question
2006-03-29 by Mark Savoia
Define big scans.
On Mar 29, 2006, at 8:55 AM, michael3442 wrote:
> So the question is,
Roughly in the 100+ mb range? I'm new to scanning negs for big prints,
e.g., 16x20, poss. bigger, so my estimate may be off by a little to a
lot. When a scanner is working, does it require the computer to work
full throttle and is there a limit to how much cpu & ram a scanner
needs use to work at its peak?
"Mark Savoia" wrote:
"Define big scans."
2006-03-29 by Ernst Dinkla
> location? Thanks.
If you got time then a slower computer system is as good. File
size isn't limited other than in time to process it. And if
you have to work on the faster system you probably save more
time by hooking the scanner to a separate slower system. I
sometimes end up with 500 - 600 MB files on a 1200 MHz AMD
system with 750 MB memory. There's other work to do while that
scan system runs .
Ernst
           Ernst Dinkla
www.pigment-print.com
(         unvollendet         )
