R220 questions on B&W .icc profiles from Paul Roark
2006-04-03 by mimimike43
I know the recommended printing and editing software that Paul
recommends to use for .icc profiles is Photoshop Elements.  While I do
use PSE4 for my editing,  I am using Qimage for my printing.  Would
there be anything that I should be aware of when using Qimage rather
than Photoshop for printing with the .icc profiles that Paul offers for
the R220?  Are there any settings in Photoshop Elements that should be
attended to firstly(other than editing my respective file), before I
print through Qimage re: gamma settings.
Also,  as per the .icc profile for Hahnemuhle Photo Rag,  is that for
their 188gsm. paper?  Would I need a different profile for other
Hahnemuhle papers re: William Turner(Textured Surface) matte 190gsm.?
Or even the heavier Hahnemuhle Photo Rag 308gsm.(can the 220 handle
that thick of a paper?).
Thank you in advance Paul,  or any other forum memebers.
Mike
RE: [Digital BW] R220 questions on B&W .icc profiles from Paul Roark
2006-04-03 by Paul Roark
Mike,
Photoshop and Photoshop Elements have an easy workflow for inserting ICCs in
the Print Preview.  I'm just not sure how the other programs might handle
the ICCs.  Some programs do not seem to recognize the "Create ICC" ICCs as
compatible.
>  While I do
> the R220?
I don't use Qimage, so I can't answer this one.
The working spaces should be uniform.  Create ICC assumes Adobe RGB from
what I can see.  Whether that means the color space needs to be that may be
a different issue.
300 gsm; but it should be close for 188.
Incidentally I found my PremierArt Hot Press 205 profiles do not work very
well on 325 Premier Art Hot Press.
My experience is that the grayscale ramps are usually the same, but the
tones of the papers may differ a bit.
Re: [Digital BW] R220 questions on B&W .icc profiles from Paul Roark
<paul.roark@...> wrote:
> Mike,
inserting ICCs in
handle
ICCs as
> compatible.
> >  While I do
Would
rather
offers for
> > the R220?
before I
from
that may be
> a different issue.
> Paul
> www.PaulRoark.com
Thank you Paul.
Qimage does offer a softproof for your respected image to be
printed.  I open this image in Qimage directly from Photoshop
Elements after I am done editing.  The tagged profile(sRGB or
AdobeRGB) remains with the image in Qimage.
Before softproofing and printing I would open whichever .icc profile
that I want to use.
Will let you know how it goes.
Much appreciated
Mike
BTW,  thank goodness for the copy and paste when trying to
spell 'Hahneumlenele'!
