I'm not one of the resident "rocket scientists" but I'm a sucker for a
sycophantic plea, so I'll take a shot... 8*)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Rob"
<digitalblackandwhitetheprint@...> wrote:
> 1. When opening a RAW file from my Nikon D2x, for the best final
> print quality on my Epson 2400, what should my DPI setting be in
> Adobe Camera Raw? I _think_ that the D2x native resolution is 240 DPI
> but I'm not certain. Should I just open at that resolution and then
> resize in PS2 at the end of my workflow before printing? Or should I
> open it at another resolution. I've read that the native DPI of the
> Epson 2400 is 720 DPI, but have also read some folks saying as long
> as it is a multiple of 720 (e.g. 360) that will work fine as well
> (and you can't tell the difference).
One thing that might help, and it seems to be a little pedantic, but
here goes (and someone correct me if I'm wrong here!)
PPI = pixels per inch (usually refers to image "resolution", as in PS)
DPI = dots per inch (usually refers to printing resolution)
The D2X's images are captured at 4288x2848 pixels. Until you are
ready to print the image and decide that you want 360 or 720 pixels
printed per inch of paper, the "resolution" or pixels/inch in
Photoshop are generally not terribly important; it does not change the
density of information in the file or number of pixels you have, it
just groups them into units of "screen" inches differently. So, your
files at 300ppi are perfectly fine. They would be 4288/300=14.99" by
2848/300=9.49", as far as Photoshop is concerned. If you felt the
urge, you could tell PS to change the "resolution" to 360ppi (without
resampling), at which point your image would be 11.91"x7.91".
However, until you print, these dimensions are generally unimportant.
[The only time it is important is if you select "Print Size" under
view for your current zoom - PS will use your screen resolution to
show the photo as if it were the size indicated by the current
resolution; this is so you can look at the image at the size it might
be if it were printed.]
> 2. If my original image size has a setting of 300 DPI (because I've
> already worked with the file and done all my retouching before I
> accessed your collective knowledge), at what stage should I upsize
> the image to a higher resolution (e.g. 360 dpi? 720 dpi?). Should I
> do that as the very first step before retouching? Or the very last
> step before applying unsharp mask?
I think it's best to do all of your retouching/adjustments/etc.
(except for sharpening), then save the file with layers intact so you
can make changes easier. When you print, depending on the size you
wish to print, you open the file, flatten, then resize/resample to the
DPI (dots per inch, of paper) and dimensions as appropriate. Then
sharpen and print.
The 360dpi vs. 720dpi debate for Epson printers comes up periodically;
360dpi seems to work fine for my 2400. I can't see the difference on
the papers I use if I uprez to 720. However, you can make a couple of
sample prints if you want and see if it is visible to you. Once
there's glass in front of it, 240dpi is actually fine for my purposes.
Hope this helps! Sorry for the verbosity. Corrections or comments
appreciated
Eric
