DryCreek B&W Profiles Free to Forum Members
2006-04-04 by lou4photo
Dear Forum Members:
Some weeks ago on another thread I expressed my great satisfaction
with the B&W profiles created for me, gratis, by Ethan, at DryCreek
when he made my color profile on my Epson 4800, K3 inks and Ilford
Smooth Pearl Paper. I have also tried these B&W profiles(neutral,
platinum, sepia, browntone and cool tone) on Silver Rag with similar
good, metamerism free results. Actually the results are stunning and
the toning options, in particular the platinum, are restrained and
quite beautiful. I realize this CM approach to B&W printing is not
everyone's cup of tea but to others like me than want to print B&W in
the same easy wysiwyg method as color images, these B&W Profiles
would be a boon to anyone with a K3 printer. I wrote to Ethan and
asked him if he would be offering these B&W profiles free along with
his color profiles as a matter of normal procedure. With his
permission I have included his reply below: The short answer is YES
for forum members but depending on your setup your milage may vary.
Realize you may not geat great results with every inkset on every
printer. But if you have a newer K3 printer this is great added value
to an already excellent color profiling service. Just let Ethan know
you are a forum member when you order and that you want the extra
profiles. I don't work for DryCreek and I have heard different
opinions about them, however my experience with them has been and
coninues to be very satisfing. Happy printing to all.
http://www.drycreekphoto.com/
Lou Meluso
Lou,
I started this email last week, ran into a time crunch, and let it
languish in the drafts folder. I'll try to pick up my train of
thought...
We have debated offering B&W profiles for over a year. I spent far
too long in late 2004 developing the technique for creating these
profiles. In most cases, the process works well. Nonetheless, trying
to eliminate unwanted color casts - all too easy to spot in a B&W
print! - is not a sure bet.
There are cases where a B&W profile will not be perfectly neutral
over a certain tonal range. Fixing the problem is simple if one has
the offending printer at hand. Make a print, evaluate, edit the
profile or re-measure, print again. It usually takes one or two
iterations to dial in a recalcitrant printer. In our case, however,
the printer is anything but readily available. Doing remote edits
based on a description or relying on snail mail to shuttle prints
back and forth is a time consuming process. Our thoughts were that
this would require both pricing the B&W profiles at an unreasonable
level and spending more time than any of us desire tweaking and
editing output.
Further confounding the process is the ugly fact of metamerism. While
we can make a profile that gives neutral output under a particular
lighting condition, this does not necessarily hold true for all light
sources. For example, the original Epson UltraChrome inks shifted
between a green and magenta cast depending on the lighting. The
primary culprit in the metamerism was the yellow ink. Various RIP
vendors make specialized B&W printing modes that disable the
offending yellow ink, however this requires control over the
individual inks. A profile is not a printer driver, so it can not do
this. The moral is that metamerism can not be eliminated by a profile.
Our dilemma is that we have a methodology that works well in most
instances, but we can not guarantee it. Some printers and inks are
simply unsuited for B&W printing unless the output is viewed under
carefully controlled lighting conditions. The toning options are
based on measurements of a bunch of my own prints as well as those of
my colleagues. We use the rendering intents as a means of giving
different strengths, but we do not want to make individual
adjustments based on each photographers preference -- back to a sane
pricing model once again.
So far, we have offered the B&W profiles to customers who mentioned a
preference for B&W work or sounded more savvy than average. We have
yet to charge for the B&W profiles - it's been solely a gratis
program. I do not want to include this for all our general customers,
as many will not use them enough to justify the extra time and effort
on our end. If you want, I could make the following offer to the
Digital B&W group members:
Purchase a regular color profile from us and we will throw in the set
of B&W profiles at no extra charge. Include a note to my attention
along with which archive format to put the profiles in: WinZip or
Stuffit. The B&W profiles come with neither guarantee nor support. If
they do not work satisfactorily, we would like to hear why not, but
are not going to commit to rounds of edits and tweaks. For folks with
earlier Epson pigment printers - those with the original UltraChrome
inks or their third party equivalents - please do not order the B&W
profiles unless your prints will be viewed only under high quality
D50 lighting. Ill-behaved printers really require a RIP for B&W work.
Feel free to post the above to the Digital B&W group. I have no
problem providing the B&W options as long as people know their
mileage may vary.
Ethan
2nd 220 for B&W only?
2006-04-06 by Steve and Ann Taylor
I had previously asked if anyone could help me get a network shared Epson
2200 to work with QTR from a Win2000 computer on the network. Nobody
responded, maybe it's too easy a question and I should be able to figure
it out myself. Anyway, I just bought a used 2200 that I want to dedicate
to B&W only and will connect it directly to the Win2000 computer with QTR
running on it. My other 2200 will then be used only for color work. I will
need to clean the heads on the used printer that I just bought since I
have no idea how long it has been since the printer has been used. Should
I use the MIS cleaning catridges or get the empty MIS cartridges and fill
them with Windex? What is the feeling about B&W ink sets? I am considering
either the MIS UT7 or Jon Cone's Nuetral K7? Any suggestions? I don't
print high volume and sometimes I don't print anything for several weeks.
Steve Taylor
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
