Matboard Questions...
2006-04-07 by G Guhan Gunaratnam
Hello, I've got my cutting tools to give cutting matboard a shot. Now I need some advice on which matboard to go for and was hoping someone here might be able to help with a debate in my head. Sometimes, I get the feeling I might be getting carried away with some things, and I immediately think I have to get the best since I do like my prints. At the same time, however, I know I'm still learning and that some, or many could be reprinted as time goes on. So I'm stuck deciding whether I should get museum-grade matboard, or go with something a little cheaper. I will be showing my current run of prints to people of some importance in my life, so either way I want a good quality matboard, but I might be able to go without the archival quality of 100% rag acid-free. I'd like to hear opinions. Mats will be non-standard window sizes, so I'm not positive I'll be able to re-use cut mats on future prints (unless its for the same photograph). Regardless of which route I go, I'll be getting enough cheap matboard to practice on before making the final mats. If you shop on Dickblick.com (where I will probably be ordering from), which do you buy? Ideally, I'd like to get 40"x60" sheets to cut down (though I'm wondering whether I'll be able to handle that size - I have the work area - but my straightedge is only 36" - I'm not sure if I'll have problems cutting along the 40"). 32x40" sheets will give me fewer usable mats in the sizes I see myself using most. I'm leaning towards 20x24" mats for images in the 11x17" range (printed on 13x19"). Is that a decent size or do you think the borders will be too large? When viewing prints, I like a nice balance between the image and border size, I don't like it when the border does more than present the image. I'll probably end up doing a quick test mat using poster paper or something similar, but if anyone has experience with this window and mat size...does it scream BORDER? And a special thanks to everyone who's replied to my past posts. All your advice has lead to much improved prints. Regards, Guhan
